my heater doesnt blow hot
Posted by bcrosby, Oct 28, 2002
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support Miller Import Parts
  1. bcrosby
    bcrosby Proven Member
    Jul 11, 2002
    72
    , Des_Moines_Iowa
    What would make my heater not blow hot? Now that its getting cold out ive noticed that my heater just doesnt blow hot. Could it be the thermostat? Any ideas would be appriciated.
    #1
  2. Buck_Team_Ty
    Buck_Team_Ty Proven Member
    Sep 27, 2002
    3
    Bowling Green, Ohio
    What is your engine temp. looking like? If its up way high then its a good chance its your thermostat...
    #2
  3. bcrosby
    Jul 11, 2002
    72
    , Des_Moines_Iowa
    Engine temp is normal, right in the middle of the gauge, I had a different DSM last winter and the heater burned you out of the car if you left in on high. This car is just barely warm after a 20 min. drive to work. I just hope its the thermo.
    #3
  4. turboholic
    turboholic Proven Member
    Jul 30, 2002
    2,174
    Rialto, California
    -Check the coolant hoses that goes into the firewall by the fuel filter, they're for the heater, the hose might clog or something.
    #4
  5. abstraction
    abstraction Proven Member
    Sep 9, 2002
    337
    , Toronto_Ont
    prolly the thermostat... shouldn't cost too much to replace.. had the same problem with an old minivan i used to have.... could drive it for hours... engine would be warm..... not HOT .. but normal... heater would be frigid....
    #5
  6. crazyjoe
    crazyjoe Proven Member
    Jun 7, 2002
    225
    , Farmington_MI
    Also check to make sure you have enough antifreeze. If you're low, your heater won't perform as well. Otherwise, it cold be cloged hoses or a clogged heater core.
    #6
  7. Brodie
    Brodie Proven Member
    DSM Profiles:
    Jul 17, 2002
    118
    , IllinoisUS
    I just got my car back together and im having alot of little problems, one of them being i live near chicago and have NO HEAT. The classic heater core blowing syptoms havent happened. i just have no heat. when the car is on and the selector is to cold its DAMN cold i move it to hot, it warms up like ONE degree, what do i do.
    #7
  8. Brodie
    DSM Profiles:
    Jul 17, 2002
    118
    , IllinoisUS
    btw i checked the HVAC controls and there doesnt seem to be a problem there.
    #8
  9. turbolover2
    turbolover2 Proven Member
    DSM Profiles:
    Oct 5, 2002
    338
    Long Island, New_York
    Does it get warm if you hold the RPMs up? If so, check the coolant, it's probably low. From there, look for a leak.
    #9
  10. Brodie
    DSM Profiles:
    Jul 17, 2002
    118
    , IllinoisUS
    the heat doesnt blow hot no matter what i do, i checked for leaks and found none. but i can try adding more coolant.
    #10
  11. laserblue
    laserblue Proven Member
    Oct 18, 2002
    605
    North Haledon, New_Jersey
    Does the temp gauge read 1/2 way up like normal? If not, the thermostat may be stuck open. Does the radiator feel hot after some driving? Again- it may be the thermostat or it could be a weird circulation problem. Do the hoses [in the engine compartment] to and from the heater core feel hot? Maybe the heater core is clogged. Can you definately 'feel' and 'hear' that the temp knob is actually moving 'something' when you turn it? If the hoses are hot but no heat is blowing then perhaps the baffles/air directors may not be moving to the correct position. Does the air feel warmer at low speed fan setting? That's signs of poor circulation, cool water temp or partially clogged core. All these things must be checked. I've had cars with weak heat but never with no heat! My Laser has the hottest heat of any car that I've ever owned. LET ME KNOW WHAT YOU DISCOVER.... If all else fails--- I hear that Florida is nice this time of year!!!!!!:cool:
    #11
  12. Brodie
    DSM Profiles:
    Jul 17, 2002
    118
    , IllinoisUS
    well. To everyone still tuning in. I have heat now
    it turns out that the selector on the box broke. From what i could see before the selector moved and worked fine but its was actually stripped and not moving anything. So i pulled one from my other car (parts car) and replaced it and now im all good.
    #12
  13. laserblue
    Oct 18, 2002
    605
    Wow, you mean that my post might have helped !!! Great, YOU'VE GOT HEAT. I guess that with me writing hundreds of posts ... sooner or later I'd be of help. [I'm talkin' about the part in my post above where I wrote "Can you definately 'feel' and 'hear' that the temp knob is actually moving 'something' when you turn it?"]
    Good luck, great holidays,
    JOEL [my real name, not nick-name]
    #13
  14. Redspyder98
    Redspyder98 Proven Member
    Oct 12, 2003
    10
    , OntarioCanada
    My heater creates heat only when I rev up the engine. When I am on Idle it doesn't heat up at all. The higher the engine is reving the hotter the air gets, and it gets very hot after a while of driving.
    I need you help, if anyone knows what possibly could be wrong, please tell me.
    #14
  15. fasteclipse1992
    fasteclipse1992 Proven Member
    DSM Profiles:
    Jan 17, 2003
    401
    joplin, Missouri
    sounds like low coolant add more. revin it up is causin the water pump to spin faster to be able to move the coolant through the heater core
    #15
  16. steve
    steve DSM Wiseman
    DSM Profiles:
    Feb 3, 2002
    12,364
    320
    St. Charles, Illinois
    Everytime I've lost heat in the wintertime it's been due to the thermostat failing open. If your getting heat at a standstill but not with any air moving over the car try replacing it with a OEM thermostat.
    Steve
    #16
  17. igorsgonemadd
    igorsgonemadd Proven Member
    Aug 10, 2003
    46
    Broken Arrow, Oregon
    anyone ever have there heater quit blowing. Well i just did so i tried replacing the heater motor that didnt work. I have checked fuses all seem to be good assuming i have checked the right ones anyone have this happen?
    #17
  18. leakyfaucet
    leakyfaucet Proven Member
    May 29, 2004
    782
    cincinnati, Vermont
    Are you saying the fan doesn't work?
    #18
  19. igorsgonemadd
    Aug 10, 2003
    46
    Yes the fan does not come on.
    #19
  20. Defiant
    Defiant DSM Wiseman
    DSM Profiles:
    Jan 13, 2003
    25,202
    112
    glorious Galt, California
    First guess: It's the resistor pack in the heater, just downstream of the blower.
    #20
  21. igorsgonemadd
    Aug 10, 2003
    46
    Ok not to sound like a complete idiot but what in the world is a resistor pack? Your not talking about a relay are you? Please explain more I would greatly appreciate it
    Thanks Igor
    #21
  22. Defiant
    Defiant DSM Wiseman
    DSM Profiles:
    Jan 13, 2003
    25,202
    112
    To control the speed of the heater blower, the switch on the dash runs circuits through a couple of resistors. Follow the wiring down to the heater housing, you'll see where they go to the side of the blower housing.
    http://www.dsmtuners.com/forums/showthread.php?t=97686
    They use resistors because it's the cheapest way to control the speed of high-amperage devices like blowers. It's in the heater airflow because they get hot as all hell.
    Uh... you did already check your fuses, right?
    It could also be that the dash switch has taken "le merde tres plus grand", or that the harness is unplugged. You been dicking around under there lately?
    #22
  23. igorsgonemadd
    Aug 10, 2003
    46
    Thanks Defiant you really seem to know these cars. I am going to try to look at this more tonight (my wife has the car now). I do not think it is a fuse because it starteds working once then quit again shortly. Also I read the thread you pointed out, im sorry I didnt search in the first place. I will in the future. However in that particular thread his hi speed worked. None of my speeds work. So do you still think it could be the resistor pack? Thanks again fo your help.
    Igor :thumb:
    #23
  24. Defiant
    Defiant DSM Wiseman
    DSM Profiles:
    Jan 13, 2003
    25,202
    112
    If you're eating fuses, there may be a short in the circuit.
    #24
  25. igorsgonemadd
    Aug 10, 2003
    46
    Yippee I have heat. Weird but all I did was replace a fuse that wasnt broken in the first place. I checked the wires going to the resistor pack with a test light and got no power so I figured that it was in the switch or somewhere before the switch. But when you turn the ac on and turn the dial the auxillary fan came on, so I figured that if it is sending power to that then it is probably sending it to the blower to. So I checked my fuses again and I noticed when I pulled the fuse out that there was carbon on it and underneath it looked kind of burnt but the fuse wasnt broken. So I thought maybe the carbon was keeping it from making good contact or maybe the fuse was bad (if that is even possible). So I replaced it and crossed my fingers and whala I have air. I am kind of concerned about the area that appears to be burnt. Should I be? I had stereo, amps and subs put in when i got the car. Maybe they blew something then. So should I be worried. :confused:
    #25
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
