My first custom turbo. S16->20g
Posted by 93xsg, Oct 12, 2017
Please Support STM Tuned
  1. 93xsg
    93xsg Proven Member
    105
    4
    Joined Jul 3, 2011
    Sequim, Washington
    Note: Always balance your full rotating assembly when modifying a turbo, even if each part is individually balanced. See Justin's post below for a video.
    Just thought I'd share with everyone my latest project.
    Had an old small 16g sitting around from my old car, so I thought I'd learn how to rebuild them, mess around and make a good steet turbo.
    A small 16g requires machine of the bearing housing to accept the 20g wheel.
    If you have a big/evo 16g this mod is bolt on!
    There's a small recess that the wheel sits into. The s16g has a smaller diameter wheel, hence the machining. Cost $50 locAL machine shop.
    I used all turbo lab parts. Including mhi rebuild kit, the 7cm evo 3 turbine housing, and a 3" tdo6 cover with 20g wheel.
    The wastegate is a Kinugawa adjustable. It came with like 7 springs too! I wanted to keep this turbo internally gated. I had to drill and tap another hole for the wastegate, and make spacer brackets. So I'd recommend if using this wastegate, to also use Kinugawas cover.
    Log in/Register to remove ads
    My DSM:
    Loading...
    GPLaserRS and Spideydsm99 like this.
  2. Spideydsm99
    Spideydsm99 Proven Member
    227
    40
    Joined May 30, 2017
    Cherryville, North Carolina
    Seems really cool man. Keep up the awesome thread!!:hellyeah::applause:
    My DSM:
    1997
    Street Build
      manual
    Loading...
    93xsg likes this.
  3. 93xsg
    93xsg Proven Member
    105
    4
    Joined Jul 3, 2011
    Sequim, Washington
    Thanks Spidey! That's about it for this thread. I still have to finish making spacer brackets for the wastegate. (Have 5 washers on each right now LOL). But Ill post results of how she performs when I finish the car! Hopefully only a few more weeks. I've had it 5 years now, never driven it haha :p
    My DSM:
    Loading...
    Spideydsm99 likes this.
  4. JusMX141
    JusMX141 Moderator
    12,648
    622
    Joined Dec 13, 2005
    Greensburg, Pennsylvania
    Was the bearing housing recess actually cut in the one pic you posted? Bearing housing groove should be 69.2mm on any wheel with a 68mm exducer...if it's cut in that photo it's way too close to the wheel.
    If you use an angled T04B/TA49 actuator bracket it gives a lot more clearance between the turbo and radiator...although I'm not sure how it would work with that bulky billet actuator. The Garrett actuator is a bit more compact and an be mounted "higher" on the cover so it's not hanging off the front and interfering with things like cooling fans.
    Also, always get the assembly balanced when replacing one or both of the wheels if you want it to last- especially on something as small as a TD05H turbo that reaches shaft speeds of 150k. I've balance-checked assemblies that needed no additional correction at all and I've balanced checked some that were out so bad the vibration would've caused the shaft to break...and these were with all new parts. This video explains stackup unbalance a little better and can often mean the difference between a turbo that works properly and one that fails before the first oil change:
    Loading...
    joemamma, 93xsg, lasershark and 3 others like this.
  5. 93xsg
    93xsg Proven Member
    105
    4
    Joined Jul 3, 2011
    Sequim, Washington
    Hey Justin,
    Thanks for all the info!
    I had asked the machine shop (not a turbo specific) to match the tolerance gap on the old wheel.
    Just broke out the micrometer, got 67.95 for the wheel and 68.45 for the bearing housing -.-
    As far as the wastegate goes, she clears everything just fine! Have about 4 fingers between the wastegate and smack dab in the middle of the radiator. Should work perfect with the slim fans I'll get.
    I was trying to find info on a stock wastegate that would work, but gave up after not finding much info, and locating this one. And I didn't want to do a bunch of fabbing. After all was finished, I had to drill and tap one hole, and grind about 1/16th off the cover to make this one work.
    And the balancing, all the research I did, led me to believe it was a pretty good shot to not have the entire assembly balanced. (As each piece has been individually balanced). I see now exactly why this is important! And I'll add a not to my first post just incase anyone else attempts. Thanks man. Pmd you as well about balance/machining :)
    My DSM:
    Loading...
  6. ec17pse
    ec17pse Freelancer
    2,559
    668
    Joined Nov 1, 2008
    London, Europe
    nice work, I modified my e3 16G and make a bracket for my forge motorsport actuator to give me more room and to clock the comp housing down, so i know the work involved and its a great idea for more space and to get rid of that J pipe IMAG0583_1.jpg
    My DSM:
    1997 Mitsubishi Eclipse GST
    Road Race Build
    175 whp   180.1 lb/ft
    Loading...
    JusMX141, GPLaserRS and 93xsg like this.
  7. 93xsg
    93xsg Proven Member
    105
    4
    Joined Jul 3, 2011
    Sequim, Washington
    Dude, that's the sickest 16g I've ever seen! Love how you clocked it and added the outlet. Nice fab work on the wastegate as well. I really want to learn how to weld soon. Too many other things going on at the moment to invest :p
    My DSM:
    Loading...
  8. ec17pse
    ec17pse Freelancer
    2,559
    668
    Joined Nov 1, 2008
    London, Europe
    Thanks, it is a oretty unique setup compared to most, while i would have got a 20g comp housing i did not want to use a 20g wheel at the time, so this was what i came up with, makes it tighter and less piping and as i said gets rid of that crappy J pipe which uses alot of space! The bracket for the actuator was kinda cool to do as i had zero refference to follow and i just used a 16g aftermarket actuator and went from there, i had to make sure it did not bind though upon opening. The turbo is completely custom from start to finish,
    I like seeing custom ideas on turbos if its for a reason like ours, great to see what peoples minds come up with
    My DSM:
    Road Race Build
    175 whp   180.1 lb/ft
    Loading...
  9. lasthope05
    lasthope05 Proven Member
    780
    163
    Joined Mar 31, 2006
    Philadelphia, Pennsylvania
    Nice! Im stealing that WG mount idea since I need to clock the compressor cover also. ;)
  10. 93xsg
    93xsg Proven Member
    105
    4
    Joined Jul 3, 2011
    Sequim, Washington
    Years ago, seeing other peoples builds and custom fab on this site, is really what inspired me to get where I am today. Still have a lot to learn but it's a great journey.
    I've always hated the j-pipe anyways. bolting to the turbo outlet has always caused me trouble -.- And youre totally right about how much space it takes up. I was unable to run 2 fans when I had the white car in my profile pic.
    Howd you test the travel of the arm, to check for binding? Mines so damn stiff its hard to move at all haha. Reckon I could take out the spring or something. But mine's a pretty straight shot.
    My DSM:
    Loading...
  11. ec17pse
    ec17pse Freelancer
    2,559
    668
    Joined Nov 1, 2008
    London, Europe
    To test it i simply put an air line on the nipple and tested it to 30psi to see how far back it sent and i tweeked it from there, all though my first attempet was damn close i only had to do a small twist for it to be perfect.
    Ever since i wanted to run a 16g i was always aginst the J pipe! No way was i ever going to run one so i had no choice to modify it or pay alot more for a turbo i wont be ready for in years LOL
    My DSM:
    Road Race Build
    175 whp   180.1 lb/ft
    Loading...
  12. ec17pse
    ec17pse Freelancer
    2,559
    668
    Joined Nov 1, 2008
    London, Europe
    Mine of the OP's? Either way we need patent fee's please haha
    My DSM:
    Road Race Build
    175 whp   180.1 lb/ft
    Loading...
  13. lasthope05
    780
    163
    Joined Mar 31, 2006
    Yours, haha. I was just going to weld a stand off on the cover but your way is much cleaner/reversible with the stock waste gate.
  14. ec17pse
    ec17pse Freelancer
    2,559
    668
    Joined Nov 1, 2008
    London, Europe
    yeah i considered that aswel but wanted it smooth as so i used the factory M6 bolt holes which does make it alot nicer
    My DSM:
    Road Race Build
    175 whp   180.1 lb/ft
    Loading...
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrications OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports Tire Rack VR Speed Factory
