My clutch need to be bled out
Posted by bboyroxas, Dec 23, 2012
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support Boostin Performance
  1. bboyroxas
    bboyroxas Proven Member
    Sep 5, 2012
    65
    gallardo, Tennessee
    I clutch only engages at the bottom just noticed it this morning can I bleed the clutch fluid from the slave cylinder will that do it
    #1
  2. Simadowna119
    Simadowna119 Proven Member
    DSM Profiles:
    Jul 11, 2009
    193
    Lincoln, Nebraska
  3. 95TalonTSI4EVER
    95TalonTSI4EVER Probationary Member
    DSM Profiles:
    Oct 23, 2012
    19
    Douglassville, Pennsylvania
    good luck buddy. its a #@@#$!! joke and I still cant get my to grab right.
    ### let us know exactly what you did if you fix it
    #3
  4. gusu
    gusu Proven Member
    Sep 9, 2009
    1,359
    24
    Keizer, Oregon
  5. JusMX141
    JusMX141 Moderator
    DSM Profiles:
    4
    Dec 13, 2005
    12,573
    531
    Greensburg, Pennsylvania
    If the clutch is grabbing right off the floor, bleeding isn't going to do much unless you're positive there is air in the line....you need to crawl under the dash and adjust the clutch properly at the master cylinder.
    #5
  6. bboyroxas
    Sep 5, 2012
    65
    gallardo, Tennessee
    It is normally under pressure as soon as I apply my foot and I like this feeling today it was like it sunk 2 inches without much force applied
    #6
  7. Simadowna119
    DSM Profiles:
    Jul 11, 2009
    193
    Lincoln, Nebraska
    Seeing how its so easy to bleed the clutch you should just do that and get back to us. Make sure the rubber seal in the reservoir is not all out of place.
    #7
  8. chevaholix
    chevaholix Proven Member
    Jun 7, 2012
    53
    kennerdell, Pennsylvania
    Id go with justin and atleast try ajusting it... ## clutch aint just gunna get air in the line either your clutch is goin or it needs ajusment...
    #8
  9. JusMX141
    JusMX141 Moderator
    DSM Profiles:
    4
    Dec 13, 2005
    12,573
    531
    Well if it just happened out of the blue, check the clutch fluid in the reservoir...often you can have a small leak in the master or slave cylinder which drains the fluid slowly over the course of a few months. Once the level gets low enough to let air into the system, suddenly your clutch action changes.
    Look at the slave first- if it looks dry, stick your head under the dash and see if there's a trail of fluid running down the firewall from the master cylinder then you know where your leak spot is. ;)
    #9
  10. ChiTownHussla
    ChiTownHussla Proven Member
    DSM Profiles:
    Nov 16, 2010
    984
    3
    Chicago, Illinois
    Maybe his clutch is just dying
    #10
  11. TopGun8818
    TopGun8818 Proven Member
    DSM Profiles:
    Oct 3, 2007
    127
    San Jose, California
    How many miles does the master cylinder have on it? I've replaced mine twice on my 2g gsx. At 78k when I bought the car and again at 150k - I guess they tend to go out around that mileage. If you have some cash to spend - get the SS braided kit that deletes the middle section and goes directly from your master cylinder to your clutch slave. That's what I did and the response is great on my clutch. I'd follow everyone's recommendation above first before replacing it though.
    #11
  12. red_devil
    red_devil Proven Member
    DSM Profiles:
    Jul 13, 2005
    901
    14
    Cape Coral, Florida
    They can also leak inside the car.
    #12
  13. bboyroxas
    Sep 5, 2012
    65
    gallardo, Tennessee
    Yes my fluid was very low I topped it off again twice and I have been pumping it hoping the air will leave is there a blender valve on the slave
    #13
  14. ChiTownHussla
    DSM Profiles:
    Nov 16, 2010
    984
    3
    Chicago, Illinois
    yes 10 mm
    #14
  15. JusMX141
    JusMX141 Moderator
    DSM Profiles:
    4
    Dec 13, 2005
    12,573
    531
    A dying clutch tends to grab higher in the pedal travel until it eventually slips all the time instead of grabbing right off the floor.
    #15
  16. ChiTownHussla
    DSM Profiles:
    Nov 16, 2010
    984
    3
    Chicago, Illinois
    you are right.
    adjust your pedal according to the links above. that should do it
    #16
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
