My car suddenly shut off while idling, and now wont start but it does turn over.
Posted by 96gstdsm, Sep 29, 2007
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support Kiggly Racing
  1. 96gstdsm
    96gstdsm Proven Member
    Aug 7, 2006
    781
    monroe, New_York
    Was driving my car to the bank with a friend. Got there and while he was going to the atm the car suddenly just turned off instantly. Not like a normal stall or anything.
    Tried to turn it on and it almost went on but didn't. Tried a few more times and it did turn over just didn't start.
    I tried roll starting it and nothing either. Tried multiple times again and nothing would help it start.
    Would a bad isc cause this? Or what would be the best guesses to check? I could smell fuel also so I believe it is getting fuel to the engine. The MAS is plugged in, the tps is connected as well as the isc. Checked all the connectors on for the spark plug wires and all. New spark plugs. New 190 fuel pump rewired. Any ideas on what would just make the car shut off all of a sudden when it has been running fairly decently?
    It has been stuttering on and off recently though. Got much worse with the stuttering when there were some 650cc injectors in the car. It would only stutter just when getting into boost.
    When I had the 650's in it was unable to boost at all. Would just stutter the whole time.
    #1
  2. aceofriches
    aceofriches Proven Member
    DSM Profiles:
    Aug 17, 2007
    85
    Spokane, Washington
    650's with no fuel management??? even if their not on there anymore... your plugs are fouled---- Get a AFPR... and new NGK's
    #2
  3. 96gstdsm
    Aug 7, 2006
    781
    monroe, New_York
    Sorry forgot to mention that I did replace the spark plugs after putting back in my stock injectors
    #3
  4. dsm-onster
    dsm-onster DSM Wiseman
    DSM Profiles:
    Jul 11, 2004
    8,218
    75
    Bloxom, Virginia
    Did you check the MPI fuse? It should be at the "+" battery terminal.
    #4
  5. 96gstdsm
    Aug 7, 2006
    781
    monroe, New_York
    Not sure what that is. What does it looks like? Not a standard fuse right?
    #5
  6. spinz4
    spinz4 Awaiting Email Verification
    DSM Profiles:
    Jan 21, 2004
    222
    Honolulu, Hawaii
    Timing belt is still there right?
    dsmftw.com
    #6
  7. ilikespeeding
    ilikespeeding Proven Member
    DSM Profiles:
    Nov 13, 2005
    620
    4
    Greenville, North_Carolina
    Probably wouldnt turn over if there wasnt a belt. LOL
    #7
  8. 96gstdsm
    Aug 7, 2006
    781
    monroe, New_York
    Yeah it's still there, haven't had a chance to see if it skipped a tooth or something yet though.
    #8
  9. ilikespeeding
    DSM Profiles:
    Nov 13, 2005
    620
    4
    Ill be right there with you if you have skipped..
    #9
  10. Black91TSiAWD
    Black91TSiAWD Proven Member
    DSM Profiles:
    Nov 30, 2004
    170
    Binghamton, New_York
    Fuel pump?
    #10
  11. tom04841
    tom04841 Proven Member
    Jul 21, 2004
    607
    6
    Rockland, Maine
    Check the mpi fuse first. If that checks out, check for spark.... have a buddy crank it over while you pull the plug wires off the plug. If you have spark, you will hear a slight popping sound. My best guess off the top of my head , is that you have a bad coil pack. I am going to rule out pump right now since you smelled fuel.
    #11
  12. 96gstdsm
    Aug 7, 2006
    781
    monroe, New_York
    OK well I checked the mpi fuse(it is the one in the line running off the battery correct? If it is that cylindrical fuse then that is fine.
    Checked for spark and I am getting spark. I did not smell fuel this time however.
    Is there a fuel pump fuse? Or does the mpi fuse also work with that or just the injectors.
    How many fuse boxes are there? Just the 2 or is there one I am not aware of?
    Any other ideas I should check?
    #12
  13. DSMunknown
    DSMunknown Proven Member
    Sep 16, 2004
    2,950
    27
    Worcester, Massachusetts
    Similar situation happened to me. My balance shaft belt came off and knocked off my CPS.
    If you care to read more, click here.
    #13
  14. 96gstdsm
    Aug 7, 2006
    781
    monroe, New_York
    I have removed the balance shafts and I have a 6 bolt block with a green top CAS. That is still attached and I checked the wiring and seems to be all connected correctly from what I can tell.
    #14
  15. DSM nOOb
    DSM nOOb Proven Member
    DSM Profiles:
    May 17, 2006
    357
    5
    Columbus, Ohio
    if that were the case he wouldnt be getting spark either... check the fuse that u put in with the rewire kit. if it is blown check the ground for the fuel pump as it may happen again.
    #15
  16. edenTSI
    edenTSI Proven Member
    DSM Profiles:
    Apr 14, 2007
    85
    Regina, Saskatchewan_Canada
    most likely your fuel pump. same thing happened so i put a new one in and fixed the problem. mine happened when i was on my way to school :( there not hard to change
    #16
  17. 96gstdsm
    Aug 7, 2006
    781
    monroe, New_York
    Well thanks everyone for the help. Checked the fuel pump and the power wire had been disconnected due to some crazy splicing done for some reason. Connected it back up and it runs great.
    Could that possibly be the cause of my stuttering problem I have been having recently? It comes and goes so maybe the connection was really loose and was cutting in and out? I also have been hitting fuel cut a bit at around 14 or 15 psi with big cams though and 450 injectors right now.
    For now just happy that I can drive my car though.
    #17
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
