- Thread starter
- #51
VETDRMS
- 340
- 21
- Jun 1, 2006
Vancouver,
Washington
rx7ttlm Yes, the intake is a little undersized for this motor but I wanted to try this combo out before moving up. I think it will be a pretty killer street setup as a daily driver, but we'll see...
I picked up the cams from the machine shop and when I got there I noticed there was an Evo MIVEC cam sitting with the box. They tapped it to match these, which use a 12mm bolt instead of the 8mm bolt the late 2g uses! ?
The few options were to try and plug and re-tap the end of the cam or drill out the trigger cup and use a 12mm bolt. I decided to not mess with the cam anymore for fear it would get messed up further. The only thing that would fit in the trigger cup was a 12mm cap screw so I picked up a grade 12.9 12x1.25x35 cap screw and went back to the machine shop to have the trigger cup opened up. Hopefully this works and being bored out to 12 mm doesn't weaken the cam too much. I plan to torque the bolt to whatever the Evo spec is and use a healthy amount of red Loctite.
I started on the install and first checked to make sure the cam spun freely in the bores and I never noticed how far off center the cam lobes are in relation to the valves on these heads. Why are they like this? They start pretty on center on the #1 cylinder but get further and further off center the farther down the cam you go.
On cylinder #4 the lobe is very close to the cap and the valve centerline is nearly on the outsize edge of the lobe. Is this normal?
Other than that, does anyone know how to get the BLE solid lifters set for zero lash when degreeing the cams? The lock nut sits flush down in the hole so it isn't possible to lock it down.
Also, what are you guys using to space the degree wheel out from the crank?
Thanks!
Thanks!
