elocneas
- 109
- 7
- Oct 11, 2012
Nashville,
Tennessee
I have a MR2 power steering set up that was on a 1999 gsx. It has welded bungs on the stock power steering reservoir. It as the high pressure lines that were built and ran through the frame rail. The pump was mounted where the ABS was located (ABS was removed from this car). One end that was on the rack I had to cut off so a new end will need to be built. Also, the steering sensor that hooks up to the column I could not get off the car and that will need to be purchased also to make the system work. All the wiring, relay, computer, pump, lines, fittings, reservoir are included with sale. All of the electrical is built just match the correct colors to the sensor, connect power, and ground.
You will need to: Build 1 line and purchase the column sensor to make this setup work.
Price is 450 shipped 400 picked up and firm on price. Located 37115.
I can provide pictures upon request.
