911gdsmboostin
- 390
- 22
- Sep 5, 2014
Irwin,
Pennsylvania
Okay guys reall need some imput on this I had a similar thread but this one focuses on 1 thing the front motor mount.. recently I bough a 1991 tsi with a build 6 bolt motor in it guy said it was out of a 2 g.. either way shulda fit right in like it was at home.. wel it did but he decided to make his own stuff for what reason I will never know nor want to.. I had the rear mount bracket to replace the abomination he made to make it work so I got it installed the number I believe is the 194 bracket.. that was the rear and an easy fix... now im on to the front where he decided to cut out the main anchor off the cross member and move it down.. the reason why was the bottom hole for the front mount was broken off.. which I have devised a way to fix it while in car so I decided to get the anchor ready to get put back not I know the bottom half needs cut back out and rewelded but I haven't gotten that far I put the top bolt back in place to see where it would reside and find the holes are wayyy off.... and im not sure why I have looked and looked and cant even find pictures of it or what I might need to fix it or anything I am asking for any help please a picture is worth a 10000000000000 words and I can make something work if needed and probly will if this doesn't come together but I woul dlike it to work the way it was soposto.. so heres some pics as you can see the bottom anchor is still where he had welded it and I just took the motor mount out and put the top bolt in place to see where it would sit but I cant see how it will move/rotate the fit the hole on the motor bracket it self.. I tried jacking the motor up but its solid and lifts the car too.. also the side mount by cam gears I can see is in bind or something he used a hacked side mount and I have the bracket to the ft half and pws and wondering if I should use it and get a new bracket or not.. ANY WISEMAN please help. what am I not seeing ??? I know thiers a problem or I am missing something? and the brocken bolt thing don't worrie about I have a good idea for what to do for that.. but any help is much appreciated any pictures please would help tremendously I cant find hardly any pics online or on any site they just show the mounts none are installed or in place that I can see what I need to do?? do I have the wrong front bracket? or is something else wrong?? also I think the front bracket number is 394? I think theirs a pic of it please help guy really want this done so the motor can be finished and I can finally drive this baby!! THANKS IN ADVANCED
