missing axle and driveshaft bolts
Posted by eclipse_16g, Apr 8, 2010
Please Support Miller Import Parts
  1. eclipse_16g
    eclipse_16g Proven Member
    190
    Joined Oct 8, 2008
    Naugatuck, Connecticut
    so i went over the new shell the other day for what i thought was the last time. i noticed almost all of the driveshaft to diferential bolts and all of the 4 bolt axle bolts were missing. would it be alright to put regular bolts in or is there a certain number or strength bolt that i should be using?
    Log in/Register to remove ads
    My DSM:
    Loading...
  2. Redwidow
    Redwidow Proven Member
    366
    7
    Joined Aug 11, 2008
    Coldwater, Michigan
    OEM Is the best because they will break if they are not the correct strength.
    Here are the Part numbers and quantities you will need.
    Driveshaft to Differential: Bolts: MB000938 Qty: 4
    Nuts: MB154075 Qty: 4
    Axles to Axle cups: Bolts: MB 160664 Qty: 8
    Nuts: MF430122 Qty: 8
    You will also need 12 washers but any will work
    My DSM:
    Loading...
  3. eclipse_16g
    190
    Joined Oct 8, 2008
    thank you that was exactly what i was lookingor. can anyone geustimate what these bolts are gonna run me?
    My DSM:
    Loading...
  4. bwhite
    bwhite Proven Member
    281
    Joined Mar 5, 2002
    Brook Park, Ohio
    Just call your local dealer. He gave you the part numbers.
  5. Redwidow
    366
    7
    Joined Aug 11, 2008
    Coldwater, Michigan
    Just guessing but I would say 1-2 dollars per bolt and under a dollar for each nut. But yea give them a call and the will give you a price.
    My DSM:
    Loading...
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
