jakeb2011
- 37
- 0
- Aug 24, 2012
Greenville,
Michigan
Ok so my 97 awd talon wont run well when its warm. The warmer it gets it, the worse it idles. This started after a rallycross on a rainy day. It first would randomly run like shit when driving like I blew a silicone coupling and then come back. Gauges dropped a few times during those times. Worked well for a month after then out of nowhere cruising and it all went out. Wouldn't run at all until cooled. Cold start runs good for a minute, second minute runs like shit popping and misfiring and by the 3rd it stalls. Doesn't like running after that.
Things I've checked
-nearly all of the harness wiring
-New alternator
-2000 miles on NGK plugs and wires
-Moved plugs around to see if misfires were consistent (they weren't)
-Moved injectors around to see if misfires were consistent (they weren't)
-No codes other than P0105 that the car has had since I bought it. Its seems unrelated because \/
-Unpluged every sensor the car can run without including MAP, O2, fuel pressure sensor, TPS. Didn't change
-New MAF
-I cleaned any little bit of corrosion I could find electrical.
-Checked grounds
-Checked ECU internals for fried solders or anything odd. Nothing wrong with it.
I'm just looking for ideas of stuff to check.
Things I've checked
-New alternator
-New MAF
-Checked grounds
