Mccc Or Sea Foam
Posted by dsm5150, Jul 7, 2003
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support Strictly Import Motorsports
  1. dsm5150
    dsm5150 Proven Member
    Feb 19, 2003
    243
    vacaville, California
    its about time for me to use soam of this stuff.it helped my laser pass smog(sea foam) about a year ago.but i have read about this stuff called mccc(mopar combustion chamber cleaner)
    what works better?and how do you use it?with the sea foam i poured like half of it into the pc valve hose then then dumped the rest in,killed the motor and let it sit for like 5 hours.all opinions are needed:thumb:
    #1
  2. Defiant
    Defiant DSM Wiseman
    DSM Profiles:
    Jan 13, 2003
    25,202
    112
    glorious Galt, California
    Not worth the time nor money. Gasoline already has cleaners in it.
    #2
  3. Bohrn
    Bohrn Proven Member
    DSM Profiles:
    Apr 28, 2002
    1,185
    Chilliwack, B.C._Canada
    oh I don't know that it is not worth it.
    On an old engine, you will get lots of crud built up ontop of the valves and pistons. Really. Just look at some old parts sometime.
    The MCCC works well, just do it like it says in the VFAQ and search around for more info.
    Also take a spray bottle of water and spray it in the throttle body once it has warmed up after you have done the treatment. It will loosen up lots more crud that the chemicals have softened. It will all go out your tailpipe.
    This will help quite noisy valves, reduce knock(hotspots on the piston, glowing carbon) and allow more freeflowing air thru the system.
    Just follow the directions.
    change your oil after and at least clean/gap your plugs too.
    #3
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
