1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
Mazda speed 6 transfercase seized?
Posted by AlexGsxCummins, Oct 20, 2018
Please Support Ace Race Parts
  1. AlexGsxCummins
    AlexGsxCummins Proven Member
    317
    20
    Joined May 31, 2014
    Bremerton, Washington
    Hey guys, working on my buddy's mazda speed 6 awd, he said he was on the freeway and the car started forcibly slowing down. Then if stopped he tried to move it and it wouldn't move. He towed it to a shop and they said the transfer case seized, I just got this home and off the trailer so I have not even had time to look under it. The shop removed the driveline and after unloading it I realized I just rolled the thing off the trailer. So I start it and drive it to the garage..the driveshaft is currently out of it, so wouldn't the t-case still be spinning.. so the front tires should have still been locked up correct? Or maybe I'm spacing something I've been busy all day haha.
    Log in/Register to remove ads
    My DSM:
    1995 Mitsubishi Eclipse GSX
    Street Build
    16g   manual
    Loading...
    Featured Products from our Supporting Vendors
  2. tametalon92
    tametalon92 Proven Member
    1,480
    291
    Joined Jan 5, 2012
    Rathdrum, Idaho
    Well, with limited info and research done, their awd system makes it look (and I can't stress how much I'm guessing) like it could be something in the rear siezed. I can't see any clutch packs or anything in the PTO, or any kind if disengagement function.
    But if something in the rear siezed then id expect issues with rolling still. So idk :idontknow:
    My DSM:
    1992 Eagle Talon TSi AWD
    Street Build
      manual
    Street Build
    14b   manual
    Loading...
  3. AlexGsxCummins
    317
    20
    Joined May 31, 2014
    That's kind of what I was thinking. I'm going to jack it up tomorrow if I get time, should be able to find out then.. just checking here with you guys incase I was spacing something
    My DSM:
    Street Build
    16g   manual
    Loading...
  4. Rekadae
    Rekadae Supporting Member
    33
    3
    Joined Jul 14, 2017
    Lapeer, Michigan
    Speed 6’s can disconnect the rear with the E-Brake it’s a fwd bias awd system that can be turned off it’s a click up I believe and it deactivated the rear perfectly normal to drive only using the front in these.
    My DSM:
    Loading...
Share This Page
Loading...
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
