maximum timing advance for a stock car?
Posted by 14.5 drift, Jul 2, 2004
Please Support Extreme Turbo Systems
  1. 14.5 drift
    14.5 drift Banned Member
    898
    Joined Feb 25, 2004
    o.c., California
    I dont really know if there are any differences with turbo cars or not, but can we safely advance timing in our cars?
    I ran across some guys who are advancing up to 15 degrees on there 240's with some high octane, I was shocked. I have only heard people bumping a few degrees.
    Any help is appreciated.
    Log in/Register to remove ads
  2. ryu
    ryu Proven Member
    335
    Joined Feb 6, 2003
    never never land, Maryland
    i would also like to know if you can do this on a stock car. not just can. but will it make power? anybody??? :talon:
  3. juso
    juso Proven Member
    20
    Joined Dec 3, 2004
    Chicopee,
    Is it 15 degree advanced from base timing or 15 degrees advanced timing?
    15 degrees advance is pretty normal timing.
    I see about 20 degrees advanced on race gas
    15 degrees advanced from base timing is a horse of a different color.
    And no you can't adjust your timing on your car unless you buy an aftermarket piggyback timing controller. Because you have a 2gen. Base timing is set by the ECU. 1G have a CAS that can be adjust for more BASE timing and in turn will give more advanced timing if the ECU sees that all is fine. If it does see something wrong(knock) it will take away timing.
    Timing will almost always make more power but you have to be able to support it.
    More fuel, high octane, stronger pistons, and so on or your motor will just melt from all the heat extra timing will create.
  4. definitiveno
    definitiveno Proven Member
    1,194
    6
    Joined Sep 8, 2004
    Reno/Sacramento, California
    way to bring back a 7 month old thread :)
    Thanks for the quick response juso :p
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
