Well I've seen alot of guys including myself struggle with the 1g master cylinder rod adjustment running out of thread and still being able to push in the slave cylinder by hand. With this happening you can't really adjust the clutch like in Jacks video. I've fought this problem every since I've owned my dsm and have tried rebuilt Jacks tranny with shimmed pivot, two act streetlite flywheels, new act clutch and pressure plate (2600), new oem master, slave, tob, clutch fork sets in the right spot and still the same problem. Finally I found a fix to this problem and its a simple fix. I took out my master adjustment rod and changed it out with a 2g rod. This gave me about 1/2 to 3/4 inches of rod adjustment. All you have to do is remove the clip around the master cylinder adjustment rod and it comes out. Throw in the 2g and install clip and reinstall the master cylinder, bleed, adjust and boost on.
This changed were my clutch grabbed, its not right of the floor anymore and also got rid of the free play at the top of the pedal I had. I'll try to get pictures of the rods side by side to post up for you guys.
GIVE THIS A TRY ONLY IF YOU CAN'T SOLVE YOUR PROBLEM THE PROPER WAY.
I'd like to hear your results if you try this method.
