PlanZero
- 1,516
- 263
- Aug 13, 2013
Easton,
Pennsylvania
Anyone ever try this method? This video seems to be the only place I found this technique
Edit: if you're having trouble with the video, basically the trick is to install the MC but put a bolt in one of the hard line ports then pump the pedal till no more bubbles. Then attach the line.
Seems too easy.Edit: if you're having trouble with the video, basically the trick is to install the MC but put a bolt in one of the hard line ports then pump the pedal till no more bubbles. Then attach the line.
