- Thread starter
- #151
EC17PSE
Freelancer
- 5,889
- 3,478
- Nov 1, 2008
London, UK,
Europe
2, i used my bumpsteer gauge kit last weekend and wanted to check the rear toe upon compression (bump toe) and what do you know, it was giving me around 2.5mm or toe each way over a 1.5" motion! Thas crazy lots!!!
So i adjusted what i could with pauls toe arms and i got it down to 0.7***mm i forget the exact number now but its just under 1mm, im in development of a rear toe kit to get me close to where i want and need to be, its going to have the same taper insert as the front and bolt style as its simple and effective to swap around/adjust, im also going to laser cut a washer to fit inside the inner eccentric washer space to central the bolt better, not really needed but if im working on this oart then i will complete it all the way in every detail possible!
I also took a video on my sports cam of the rear suspension but im having issues uploading it so i will do my best to figure out why it wont upload and post it once i get it sorted, no reason for this really but a bit of fun
