Geeb
- 384
- 47
- Apr 6, 2016
Philadelphia,
Pennsylvania
I'm using the megan SS downpipe. Cutting off the 2.5" reducer and flange and welding a full (short) 3" SS pipe to a 3" v band (mating style, female side)
Then making a 3" O2 housing with another v band (male side, both from ACEofRACE.com) to connect to the downpipe
..and even though it's a 2.60 ID (3.09 OD) V band on the turbo, AGP turbo makes a dual stepped 3.09 OD V band clamp.. The dual step part comes into play by either a 2.5" od pipe fitting inside the step, or a 3" od pipe fitting on the outside of the pipe..
I was a little confused on how could they know the thickness of the piping I'm using, wouldn't you need to know ID to fit something over the pipe??
So just to make sure it would fit the first time on all the clamps I got.. I ordered the piping from AGP also. Since all they say for the clamp is 3" od piping fits over the step, and all they say for the piping is 3" od, I'm guessing they should go together..
Anyways. My turbo is a pte6165.
And I got a new manifold (looks just like map style) professionally ceramic coated black. Looks nice..
But do you guys think this plan is overkill? I'm going to have to get or make a custom o2 housing anyway since the only housings I can find are for mitsu style hot sides, unless i want to pay like 300 bucks for a custom one. And I'd have to ship out my manifold and hot side for mock up, and still be working with 2.5.. I have like 100$ worth of parts to get this done
And I'm going to be gas welding it with oxy/acetylene and a COBRA dhc 2000 (this thing is sickk)
Lmk what you guys think..
