Lucas PS Stop Leak a PS fluid substitute??
Posted by a_scobel, Sep 6, 2005
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
  1. a_scobel
    a_scobel Proven Member
    DSM Profiles:
    Jun 6, 2003
    799
    21
    Alexandria, Virginia
    Just checking..Would it be alright to completely drain my PS fluid, and refill with nothing but Lucas Power Steering Stop Leak??
    I don't have a leak, but I hear this stuff might work if your PS pump is whiney until the car warms up.. Figure I'd give this a shot before I drop $115 bucks on a new pump.
    #1
  2. BaddAssGst
    BaddAssGst Proven Member
    Dec 27, 2004
    746
    19
    Toledo, Ohio
    I don't know about DSMs because they can become quite finicky but I know a couple guys, who run Chevy motors, that come in to my work and that is all they run. They swear by the stuff.
    #2
  3. Defiant
    Defiant DSM Wiseman
    DSM Profiles:
    Jan 13, 2003
    25,202
    111
    glorious Galt, California
    It's an additive, not a fluid. You might try some as an additive, but not to replace the fluid completely.
    #3
  4. TotalEclipse112
    TotalEclipse112 Proven Member
    DSM Profiles:
    Aug 21, 2002
    491
    14
    Jeannette, Pennsylvania
    He said it best, use regular PS fluid and add some of the stop leak to it, Don't try and run it without any PS fluid.
    #4
  5. Nt-Eclipse-Dail
    Nt-Eclipse-Dail Proven Member
    Oct 3, 2004
    120
    Memphis, Tennessee
    I had a bit of a 'whine' with my PS Pump that did not go away entirely by putting in fresh fluid. I used a little bit of the Lucas and it did quiet things down for me. I have been using the Lucas stuff as an additive for over a year now and have noticed no leaks or new problems since. Have you tried flushing your system out and putting in some fresh factory recommended fluid yet to see what happens? :dsm:
    #5
  6. a_scobel
    DSM Profiles:
    Jun 6, 2003
    799
    21
    Hmm alrighty then. I'll go out today & drain everything, add new fluid & a little bit of the Lucas...
    I looked in the Chiltons manual..didn't say how to drain the PS fluid. So I figure you do it by a handpump in the reservoir...or not? :confused:
    #6
  7. Defiant
    Defiant DSM Wiseman
    DSM Profiles:
    Jan 13, 2003
    25,202
    111
    Bah, you're supposed to crack the line at the rack and cycle it around and make fifteen kinds of goddamned mess. I'd pull it out of the resevoir and re-load, maybe a few times over a couple of weeks (fluid's cheap) and on the last time put in the additive. Use a low-pressure line on the bottom of the resevoir if you can get to it (or, just pull the resevoir from the fender and pour it out), but do not get any ps fluid into the alternator.
    #7
  8. a_scobel
    DSM Profiles:
    Jun 6, 2003
    799
    21
    Hm so I picked up a bottle..the directions says:
    So it's pretty much saying you can just replace your fluid with only this stuff, eh??.. :confused:
    #8
  9. igopoopy
    igopoopy Proven Member
    May 5, 2004
    1,094
    7
    tucson, Arizona
    no just use one bottle that stuff is thick i have used it and one bottle is enough
    #9
  10. Defiant
    Defiant DSM Wiseman
    DSM Profiles:
    Jan 13, 2003
    25,202
    111
    That's the resevoir, not the system. It'll mix in with the rest of the fluid in the pump, lines and piston. Kind of like an automatic transmission and its torque convertor.
    What the hell, if the pump's already bad, there's not a lot there to hurt, is there? Put cardboard over the alternator before working on the PS fluid.
    #10
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
