Low Idle and car shuts off
Posted by gotmyeclipse, Jul 7, 2012
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support Magnus Motorsports
  1. gotmyeclipse
    gotmyeclipse Proven Member
    Jun 26, 2012
    65
    Hayward, California
    Hi there i have a bit of a problem, i have an A/T dsm and its acting like a M/t, sometimes when i go to a full stop, my car engine will idle really low and then shut off. thing is i have an A/T and i dont think thats suppose to happen, i had to pump gas for the engine to keep going or put in on neutral when im on a stop. Any body has experienced this before?
    #1
  2. primo513
    primo513 Proven Member
    Jun 1, 2011
    117
    Cincinnati, Ohio
    I had a lot of idle issues with my 1g, when cruising I couldn't keep a constant speed because my idling was messed up. Lost story short, I was having an idle surge which was cause by a boost leak. My 1g would bounce around at a stopped idle going between ~600 to ~1200. I found a major boost leak and fixed some smaller ones and it fixed my idle issues. After that I was idling at a constant 1100 and it fixed my idle surges while driving. Have you ever had any issues with a boost leak? It might be something to look into anyways. hope this helps
    #2
  3. johnovision27
    johnovision27 Proven Member
    DSM Profiles:
    Apr 3, 2008
    350
    Ayr, ON_Canada
    As stated, check for vacuum leaks. My gs did something similar.
    #3
  4. gotmyeclipse
    Jun 26, 2012
    65
    Hayward, California
    thanks!
    any idea how much does it cost to get that fixed?
    #4
  5. primo513
    Jun 1, 2011
    117
    Cincinnati, Ohio
    Boost leaks aren't typically expensive, my big leak was from a gash in the pcv tube from the vc to the intake mani. Hoses are pretty cheap, like maybe a dollar per foot, I used fuel lines cause they are thicker and a lot More reliable, and that was like 2 dollars per foot or something like that. Most boost/vacuum leaks are gonna be from small tubing that either got punctured or clamp is going back. Have you ever done a blt? It's easy to find your leaks that way.
    #5
  6. 96' Eclipse GS
    96' Eclipse GS Proven Member
    Oct 9, 2011
    557
    Nowhere, Asia
    Possibly a large air/vacuum leak.... Do you have any CEL's that you know of? If not, then double check. Any work done on the car recently? I would start there. A good way to find (air/vacuum leaks) is (cigarette smoke) or (dark-colored smoke), even if you do not smoke as I do not either.
    #6
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
