low compression on all 4 cylinders
Posted by matt98eclipse, Nov 30, 2010
Please Support Extreme Turbo Systems
  1. matt98eclipse
    matt98eclipse Proven Member
    867
    Joined Aug 15, 2006
    mesa, Arizona
    Hey guys i just purchased a 95 gsx. Previous owner said that he had bought a brand new motor and car doesnt have that many miles on it. Well when i bought the car it he told me the motor was smoking a bit due to a bad turbo he said. Well i put on a known good 14b turbo and fired car up and noticed the car is still smokeing a bit.... Car seems to smoke more as it get warmer. The smoke color looks to be blue like its burning oil someone.. So i did a compression test and on all 4 cylinders and it came up with between 135 to 140 on ALL 4 cylinders.:banghead:
    What do you guys think my next step would be to do to pinpoint my problem?
    Log in/Register to remove ads
    My DSM:
    Loading...
  2. RadDsm
    RadDsm Proven Member
    1,226
    21
    Joined Apr 28, 2008
    Tigard, Oregon
    Assuming the compression test was done right (WOT and the engine up to temp), a leak down test is your next step.
    Did you do a dry and wet test?
    How to do Cylinder Leak Down Testing- Car Craft Magazine
  3. matt98eclipse
    867
    Joined Aug 15, 2006
    mesa, Arizona
    I did the test with motor at operating temp and WOT and makin sure its not getting any spark or feel.
    I havent done a leak down test yet cause i dont have one.
    I did a dry test first then on cylinder 1 i went ahead and added a cap full of 10w40 oil and compression only went up to around 150..
    Car is smokeing pretty bad.. one thing i did noticed is i looked at the top of all 4 cylinders threw spark plug holse and noticed they looked a little wet but didnt smell or look like oil at all. Also i know the car used to run really rich cause previous owner forgot to plug in front o2 sensor and lots of boost leaks!!
    My DSM:
    Loading...
  4. RadDsm
    1,226
    21
    Joined Apr 28, 2008
    Tigard, Oregon
    You can rent a tester from Autozone, or probably other parts stores.
    It's probably either rings or valve seals, but your story leads more towards pistons rings.
  5. motozachl
    motozachl Proven Member
    907
    15
    Joined Jul 15, 2008
    Cleveland, Ohio
    Since the pressure went up from doing a wet compression test I'd say the rings. The service limit is 120psi
    My DSM:
    Loading...
  6. donniekak
    donniekak DSM Wiseman
    4,226
    586
    Joined Mar 23, 2008
    Surprise, Arizona
    Do a leakdown test to see where the pressure is going. With the story of the car running rich, i'm inclined to think rings. Washing down the cylinder walls on a new engine can lead to your type of problem. Or, the engine isn't new, and has bad valve stem seals. Or, the engine isn't new and has bad rings, could be a lot of things.
    My DSM:
    1991 Eagle Talon TSi AWD
    Street Build
      manual
    Loading...
  7. matt98eclipse
    867
    Joined Aug 15, 2006
    mesa, Arizona
    Hey donnie thanks man im gonna do a leak down test tomorrow or sometime this weekend and get back with you guys on the resaults.
    My DSM:
    Loading...
  8. delta448
    delta448 DSM Wiseman
    2,779
    63
    Joined Jan 13, 2006
    Waynesburg, Pennsylvania
    Good advice up there. Running rich will wash out the cylinders even on a perfect engine build.
    Another thing to check when compression is low on all cylinders (although I doubt it in this case), is that the timing marks all line up. Too much E/I overlap will cause low readings all the way around.
    My DSM:
    1997 Eagle Talon TSi AWD (sold)
    14b   manual
    Loading...
  9. matt98eclipse
    867
    Joined Aug 15, 2006
    mesa, Arizona
    very good point ill have to check this as well but this wouldnt cause it to be smoking a bit would it??
    The motor has a pretty bad lifter tick is sounds like.
    My DSM:
    Loading...
  10. TalonJohn94
    TalonJohn94 Proven Member
    530
    Joined Jan 30, 2003
    Milwaukee, Wisconsin
    I've been searching as much as I can before I create my "Low Compression After Head Install" thread in order to cover all the bases or possibly fix before I post.
    Have you solved this problem?
    My DSM:
    1994 Eagle Talon TSi AWD
    Street Build
    16g   manual
    Loading...
  11. matt98eclipse
    867
    Joined Aug 15, 2006
    mesa, Arizona
    I did not sorry. I ended up tradeing the car for a truck.
    My DSM:
    Loading...
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
