95burgundyesi
- 816
- 9
- Feb 8, 2006
Rockford,
Illinois
I am about o order my pod, but just thought I would as if tuners get a discount because i see they have a coupon box. Well if not, i hope it gets here by the end of the week.
Note: This feature currently requires accessing the site using the built-in Safari browser.
Hmmm, does the lotek pillar replace the stock one or does it bolt up to the stock one?
Anyone know what color they come in to match a grey interior?
It replaces the stock pillar. I believe if it says 'full pillar' in the description on the Mitsu page, it does. It does for 2g's but I don't think it does for 1g's. And they come in gray. I can take a picture of mine later if you'd like to see how it matches (I have gray pillar with gray interior).
Did you have to do any drilling to mount them?
The disount will be %15.00 off any Mitsubishi product that is $29.99 and up. The coupon will be good for 30 days from date of issue.
The coupon code is "dsmgroup15". Select your item at www.gaugepods.com // Lotek Inc. and add to cart. Enter the code and click redeem coupon. Finish processing order.
The code is good for the Mitsubishi category of $29.99 and up and is valid for 1 month.
Please note that we stock a limited amount of material to make these products. So, if there is a big rush on a certain item, it will be first
come, first serve. If we run out of material the order will be placed on
back order and ship as soon as we can make more (about 3 weeks).
Currently we are awaiting material for the Evo triple. That should be in next week.
Thanks,
Lo-Tek, Inc.
I've always hated the A-Pillar pods. Every time I pass an Eclipse GS, I see that stupid thing with these really bright gauges that I'm sure are just for show. I prefer the stealth approach and just not let anyone know you have modified your car. I've been looking at this: Amazon.com:]Amazon.com:]Amazon.com: 95-99 Mitsubishi Eclipse Gauge Cluster: Automotive 95-99 Mitsubishi Eclipse Gauge Cluster: Automotive[/url] 95-99 Mitsubishi Eclipse Gauge Cluster: Automotive
That combined with a new boost and something yet to be determined would be ideal imo.
d
Every single gauge cluster pod I've seen sucks (I run both a triple a pillar pod and dual gauge cluster pods) The fitment is OK, but the main quarrel is the fact that the gauge will not sit flush inside the pod due to the long barbs that stick out of the gauge for adjustment. If you ever look at one of these, they mount so close to the plastic for the gauge cluster that it is nearly impossible to get the gauge to sit flush.
Yea, sorry, was typing in a rush and that description sounded a lot better in my head. I also cut the threaded rod off, but it's still not enough to get these damn gauges to sit flush.
I have arguably the "best" a-pillar pod on my GSX which is the Lotek/Gaugepod.com brand. It too is a 3gauge pod. So how does it compare? It's pretty darn good. The only complaint with the Glowshift brand is there are no holes, so you have to make your own when you mount it. It also doesn't come with screws and screw caps like the Lotek does. But those do NOT justify the extra price of the Lotek, so the Glowshift is GREAT! As for fitment, also PERFECT! As you can see in the pictures below:
Hmm thats odd. What brand a-pillar do you have? My brother has the Lotek pillar with Autometer Cobalt gauges and they fit fine in there, although it is close. He even has a hose barb on the back of the boost gauge that extends pretty far out and it still fits.
No, no. Sorry I didn't specify. I have a Lotek triple pod with autometer gauges and it fits like a glove. The problem I speak of is the gauge cluster mounted pods.
