kchaazz
- 1,168
- 78
- Oct 2, 2002
PENSACOLA,
Florida
So, Ive got the Ostrich and ECMLINK cable all plugged into my laptop, in the car and configured, running properly. Ive just got a few questions regarding the setup, as I have not found any useful info during my searches. I am using the DSM ADX file, availible for download on the TP website.
Load cell tracing- I can get the timing cells to trace in realtime just fine, but for some reason the fuel cells will only trace for a few seconds, or it will just say "waiting" instead of "tracing". Is it just not possible to trace the fuel cells, or is something off? If you cant trace the fuel cells, its no biggie, as I can just go by the timing cells to know which fuel cells Im hitting.
Recording the load cell trace during a WOT pull- I cant seem to get this to work. Am I supposed to log with the dash, record the log, and the cell trace will play when I play back the log I recorded?
The logger seems to be a bit laggy in comparison to MMCD on a palm- I assume this is because, by default, Tunerpro elects to log every availible sensor simultaneously. With MMCD, I like to log only timing, wideband, rpm and knock, and use the tps as the trigger to record, and I just look at my fuel trims periodically to see if theyre ok. Is it possible to log only what you want to with Tuner pro, or do I have to log everything unless I edit the ADX to remove the sensors I dont want to see?
I do have a few more questions, but these are most important at the moment.
