bilabondinn
- 1
- Apr 15, 2009
Djupivogur,
Europe
1). Any boost, vac, or exhaust leaks?
Boost leak tested 5psi above your max boost with no leaks?
Seems to be good
2). Verified mechanical timing?
yes
3). Verified base timing?
yes
4). Ignition system
COP or Stock Coil: stock
Wire brand and Age: ngk a week old
Spark Plug brand, type and Gap: ngk bpr6es at 0.9mm
5). Motor health (Compression Test)
Cylinder 1:don't remember but they were even and good
Cylinder 2:
Cylinder 3:
Cylinder 4:
6). Performed basic throttle body adjustments? No
Idle Switch:
Throttle Cable:
TPS:
BISS:
7). Compression ratio
Stock
8). Any known bad sensors or brittle wiring?
NO
9). Any DTC/CEL codes?
No
10). Electrical system
Car off (not running):
Car running:
11). Base fuel pressure and injector values
Base Fuel Pressure: 43psi
Injector Size (cc/min):850cc
12). Properly calibrated and configured wideband sensor
Sensor Brand: Innovate mtx-l
Calibration Date: 7.10.2017
13). Type of fuel
Type: 91oct
Percent of Ethanol: near 5%
14). Watched ECMlink how-to videos?
Yes
Can someone please look at my log and advise me. I was trying to dial in wot but seem to be getting knock. but i have not done any changes to the timing.
Also can you look at my settings and see if the look ok.
Seems to be good
yes
yes
4). Ignition system
Cylinder 2:
Cylinder 3:
Cylinder 4:
Idle Switch:
Throttle Cable:
TPS:
BISS:
Stock
NO
No
Car running:
13). Type of fuel
Type: 91oct
Yes
