95gsxnj
- 0
- Nov 8, 2013
forked river,
New_Jersey
Hello everyone, so for the past 2 months my build has been underway. I'm having a 6 bolt motor being built for my 95 GSX. Basicly what I am wondering is what kind of limits do I have with the following setup regarding horsepower and estimated 1/4 mile time. This setup will be run on pump gas for a while until I can get a e85/vp race gas tune.
Everything is brand new. -6 bolt built shortblock
-new crank
-acl tri metal race bearings(main/rod)
-arp main studs
-manley rods
-je pistons
- Engine gasket set
-cometic mls headgasket
-mitsu OEM front case/oil pump
-oem water pump
-kevlar race timing belt with oem tensioner&pulleys -6bolt oil pan
-arp headstuds
-6bolt cam sensor
-Break in oil / regular oil and filter after oil change -Coolant
-Lightweight aluminum 6bolt flywheel
-competition clutch kit to handle power (act have issues)
-transfluid / t-case fluid
-Bep turbine housing
-8 blade hx35
-Oil feed/return line kit
- ss punishment O2 housing/tial ewg&dump pipe
-4" fp cast intake (full kit) -1000/2000cc injectors
-Walbro 450 pump
-Afpr kit / ss braided line kit
-ecmlink v3 FULL / socket eprom ecu.
-speed density kit + tap and tig weld ic pipe for new sensor.
Punishment racing fmic hks bov
-new crank
-arp main studs
-manley rods
-je pistons
- Engine gasket set
-oem water pump
-arp headstuds
-6bolt cam sensor
-8 blade hx35
-Walbro 450 pump
