silkcity100
- 100
- 0
- Feb 23, 2003
paterson,
New_Jersey
im looking into buying a water injection kit and cant make up my mind which do you recommend and are you running one?
Note: This feature currently requires accessing the site using the built-in Safari browser.
Same thing could be said about a wastegate... or fuel filter (clogged), FPR, etc. You could say that it isn't safe because it allows you to run enough boost on pump gas that you could throw a rod out on a stock motor.bfdahl said:when I brought this question up at RRE last week they recomended staying away from any type of water injection. There reasoning was that if the car was tunned and the injection failed bye bye engine!
food for thought
Joesmoke said:I use the alkycontrol progressive controller. (www.alkycontrol.com)
Love it! Moved up from a DIY system and would never look back. Yes it controls voltage to the pump, but, it works very well.
My car relies on the injection. If it fails, and I dont back off fairly quick, Im hooped. The price Im willing to pay.
steel_3d said:What you need is a pulse width modulated injector, like fuel injectors, and I haven't seen anyone offer that yet.
Jaraxle said:I bought a shurflo pump from the web, and parts from coolingmist. Knock is completely gone, and I'm increasing timing to 19deg for another dyno tune. I will then have before and after dyno pulls for the addition of cold-air, 12->19deg timing, and water injection. I mounted the pump to a custom plate where the stock SMIC was. It pulls water from the rear tank through a 3/8 fuel hose. Trigger is 15psi, which works great, no hesitation. When it was set to ~10psi, it caused sputtering. I'm running distilled water: to fight knock only. No methanol. The idea of unmetered fuel freaks me out. My 660 greddy injectors can do that job. I only want to quench knock.
-Jaraxle
