2G Let's build a Front UCA
Posted by 99gst_racer, Oct 12, 2016
Please Support ExtremePSI
  1. 99gst_racer
    99gst_racer Moderator
    8,987
    652
    Joined Apr 5, 2003
    Coloma, Michigan
    The purpose of this thread is to discuss ideas and features for a front upper control design for the 2G cars. It's an open forum, so let me know what you do and don't want to see in it.
    My initial plan is to have a fixed balljoint and to use heims on the inboard end to make adjustments for camber and caster. To do this, one end will need to attach via a clevis. This will prevent binding when caster adjustments are being made. My only concern with this idea is that I don't know if there's sufficient clearance in the fender area when the suspension is fully compressed.
    I don't have a balljoint selected yet. I'm open to suggestions. Options are limited, because it cannot be too large in diameter, and more importantly, it needs to be shallow in depth. I'm leaning toward using the Moog OE replacement balljoint for the 2G cars, but I am open to other suggestions.
    I do have a set of prototype inboard mounts. These will be the connection of the heim to the strut tower. Final production pieces will be zinc coated to resist corrosion.
    These are my ideas so far and nothing is set in stone, so feel free to make suggestions and share ideas.
    Log in/Register to remove ads
    My DSM:
    1999 Mitsubishi Eclipse GST
    Street Build
    609.8 whp   541.2 lb/ft
    Loading...
    SAKJR, chinola69, kmetiuk and 8 others like this.
  2. 99gst_racer
    8,987
    652
    Joined Apr 5, 2003
    Coloma, Michigan
    Does anyone have a pic of the stock UCA swung all the way up? I'd like to see how much clearance is around the balljoint area in the fender pocket. I miss being able to head out to the garage and answer questions like this myself.
    My DSM:
    Street Build
    Loading...
  3. Black95TSIawd
    Black95TSIawd Proven Member
    1,621
    258
    Joined Jan 28, 2003
    Dirty, New Jersey
    Exciting stuff!
    My initial thought process was to use a stock style ball joint so that's a good idea. Any taller and it strikes the shock housing. I would say that there isn't much more room to work with outside of the stock UCA dimensions. It just barely fits on full compression.
    I have a dumb question... Are heim joints necessary on the inboard pickups? Don't we want the arm to move up and down only, and not be able to twist around?
    My DSM:
    1998 Eagle Talon TSi AWD
    184.4 whp   251.0 lb/ft
    1997 Mitsubishi Eclipse GSX (sold)
    Drag Race Build
    20g   manual
    Loading...
    95eclipser likes this.
  4. greddy_1700
    greddy_1700 Proven Member
    289
    19
    Joined Aug 27, 2006
    Regina, SK, Canada
    Do you need with or without suspension installed? My 2g is literally sitting with only the UCA's installed in the front suspension, so I can push it up and take measurements / take pictures, but if you need it based on the limits of suspension travel, then I'll be a few days away from that.
  5. 99gst_racer
    8,987
    652
    Joined Apr 5, 2003
    Coloma, Michigan
    Without suspension attached, please. I just need to see a few shots of what it looks like with the UCA pushed all the way up as far as it will go. I really just need to see how much room is around the balljoint end.
    My DSM:
    Street Build
    Loading...
  6. 99gst_racer
    8,987
    652
    Joined Apr 5, 2003
    Coloma, Michigan
    Honestly, I hadn't considered not running heims on them. A heim would offer a more fluid motion and better resistance to corrosion at the pivot point than something like a clevis attachment. That and when adjusting caster, if you didn't have a heim, you'd have to loosen all 4 nuts on the posts going though the strut towers to allow them to slightly pivot.
    I guess it could work though. I just don't know if there's any benefits to ditching the heims other than maybe a small amount of money.
    My DSM:
    Street Build
    Loading...
  7. Black95TSIawd
    1,621
    258
    Joined Jan 28, 2003
    Dirty, New Jersey
    Just thinking out loud, Paul. I'm not an engineer by any means. Adjusting caster without any additional steps is reason enough to use heims for me.
    My DSM:
    Drag Race Build
    20g   manual
    Loading...
  8. 95eclipser
    95eclipser Proven Member
    774
    284
    Joined Feb 3, 2006
    Manassas, Virginia
    I'm in for more details. Exciting that you continue to build for these cars.
    My DSM:
    1999 Mitsubishi Eclipse GSX
    Street Build
    464 whp   379 lb/ft
    10.920 @ 133.900 MPH
    Loading...
  9. greengoblin
    greengoblin Supporting Vendor
    1,070
    304
    Joined Mar 10, 2006
    McKinney, Texas
    Did you have the bird cage clevis machined from scratch or mod a unit from a supplier. Also the higher up you can move the inboard pickup the better.
    My DSM:
    1995 Eagle Talon TSi AWD
    12.830 @ 120.000 MPH
    Loading...
  10. greengoblin
    1,070
    304
    Joined Mar 10, 2006
    McKinney, Texas
    With three pick up points the arm cannot actually twist. The spherical bearings are also a really good idea because they allow from some misalignment without binding but zero unwanted movement. It's pretty much a given that there will be misalignment since the inboard eyebolts (clevis in Pauls setup) go into no indexed holes. With poly or rubber it does not matter that much but if you put in standard bearings or hard delrin things will not be good.
    My DSM:
    Loading...
  11. Dsmkauai
    Dsmkauai Proven Member
    3,921
    415
    Joined Feb 20, 2010
    Kauai, Hawaii
    I can get you that pic once I get back home ;) love your parts bro. Once my 2g is ready I'm buying everything you sell for them haha :)
    My DSM:
    Drag Race Build
    T25   automatic
    1995 Mitsubishi Eclipse GST
    12.408 @ 112.930 MPH
    16g   manual
    Loading...
    99gst_racer likes this.
  12. warren
    warren Proven Member
    267
    12
    Joined Dec 20, 2010
    houston, Texas
    if needed I could send you both of my old ones
    My DSM:
    Loading...
  13. warren
    267
    12
    Joined Dec 20, 2010
    houston, Texas
    also ive ran my galant really low and the arm does swing all the way up the frame. till it start making a hole in it.
    So the oem has plenty of clearance to move up
    My DSM:
    Loading...
  14. 99gst_racer
    8,987
    652
    Joined Apr 5, 2003
    Coloma, Michigan
    I had it made from scratch, so I could easily make changes to subsequent pieces. These prototypes mimic the OE pick-up location, but I suspect there may be room to raise it up .500".
    My DSM:
    Street Build
    Loading...
    Atuca likes this.
  15. 99gst_racer
    8,987
    652
    Joined Apr 5, 2003
    Coloma, Michigan
    I still own at least one of every arm for the 2G cars. I figured they may come in handy down the road. :) But I do appreciate the offer.
    My DSM:
    Street Build
    Loading...
  16. warren
    267
    12
    Joined Dec 20, 2010
    houston, Texas
    Ok good well if you need picture of the arms at the limit I can show you that
    My DSM:
    Loading...
  17. greengoblin
    1,070
    304
    Joined Mar 10, 2006
    McKinney, Texas
    That would be great. Move it if can be done. You would improve roll center and gain a bit of clearance before the arm makes contact with the strut tower.
    My DSM:
    Loading...
  18. greengoblin
    1,070
    304
    Joined Mar 10, 2006
    McKinney, Texas
    You might want to see how tight the clevis fits through the mounting tubes in the car is. You might be able to increase the OD of it and get a tighter fit. I seem to remember them being really loose.
    My DSM:
    Loading...
  19. Atuca
    Atuca Proven Member
    622
    45
    Joined Jan 6, 2007
    Central Valley, California
    My only suggestion is all clevis designs I've seen have looked like the below, with some more detailed posts saying this was the optimal shape based on FEA. I could look to find more info if this is of any interest, but I was just excited when this was linked to me and was the first thought that jumped to me to offer. I would have assumed you have seen these before, so if your prototypes were just proof of concepts, please disregard.
    My DSM:
    Loading...
  20. T2Small
    T2Small Proven Member
    118
    12
    Joined Dec 22, 2003
    Victoria,
    Does this help? https://goo.gl/photos/gronypdZsPhjpFnE9
    My DSM:
    1997 Eagle Talon TSi
    Autocross Build
    433 whp   352 lb/ft
    Loading...
  21. T2Small
    118
    12
    Joined Dec 22, 2003
    Victoria,
    Oh, I forgot my arms have been shortened for extra camber.
    My DSM:
    Autocross Build
    433 whp   352 lb/ft
    Loading...
  22. ViciousLord
    ViciousLord Proven Member
    345
    43
    Joined Jul 27, 2005
    Orlando, Florida
    To the top
    My DSM:
    Street Build
      manual
    Loading...
  23. 99gst_racer
    8,987
    652
    Joined Apr 5, 2003
    Coloma, Michigan
    Sorry for being MIA. I took a mini vacation down to Kentucky this past weekend and upon arriving home, I laid my Hayabusa down on the interstate on the way to work Monday morning. Messed my shoulder up well enough that I haven't been able to lay down or sleep much since. I haven't felt like doing much of anything since.
    My DSM:
    Street Build
    Loading...
  24. mountain_man
    mountain_man Supporting Member
    76
    18
    Joined Apr 18, 2007
    Lompoc, California
    Paul, thanks again for taking the initiative and developing something new!
    I apologize if my assumptions & questions below move this discussion a step backwards but hopefully it serves to further align those who read this threads thinking, allowing us to create a set of min. and max. goals for this community project.
    Assumptions:
    1.) These will be used in conjunction with Paul's front LCA's.
    2.) The user will have coilers or some other means of controlling ride height.
    3.) These UCA's are intended for autoX or road racers looking to correct suspension geometry from lowering vehicles ride height.
    Questions:
    1.) What is the min. amount (inches) the inner pick-up points need to raised in order to for new control arms to be effective?
    -It would be a real shame to put all this work in only to determine after the fact, that the major benefit is steering feel due of the switch to heims and not see significant increase in corner speeds.
    2.) What off the shelf components are available (A&A Manufacturing, Speedwaymotors, etc...) that would make this easier to manufacture and service?
    3.) Should we consider abandoning the factory inboard mounting location in favor of a bolted/welded in bracket, so that a more traditional upper A arm style can be used?
    -This is bit of a stretch but when brainstorming there are no bad ideas, right?
    4.) What are the suspension settings this kit will help users achieve?
    -I think this is one of the most important points to establish as
    Please feel free to push back on the above or expand upon it.
    My DSM:
    Road Race Build
    14b   manual
    Loading...
  25. Black95TSIawd
    1,621
    258
    Joined Jan 28, 2003
    Dirty, New Jersey
    Sorry to hear. Feel better, dude.
    My DSM:
    Drag Race Build
    20g   manual
    Loading...
Share This Page
Loading...
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Kiggly Racing Magnus Motorsports Miller Import Parts Morrison Fabrications OHM Racing Race Components Inc RockAuto Spultronix Performance Spultronix Performance STM Tuned Strictly Import Motorsports Tire Rack VR Speed Factory White Shed Speed
