Nate355RS
- 446
- 50
- Oct 25, 2012
Salem,
Virginia
1). Any boost, vac, or exhaust leaks?
None
2). Verified mechanical timing?
Yes
3). Verified base timing?
Yes
4). Ignition system
COP BR7es
5). Motor health (Compression Test)
Cylinder 1: 180
Cylinder 2: 185
Cylinder 3: 180
Cylinder 4: 180
6). Performed basic throttle body adjustments?
Yes
7). Compression ratio
8). Any known bad sensors or brittle wiring?
No
9). Any DTC/CEL codes?
No
10). Electrical system
Car off (not running):
Car running:
11). Base fuel pressure and injector values
Base Fuel Pressure: 44psi
Injector Size (cc/min): 1050cc
12). Properly calibrated and configured wideband sensor
Sensor Brand: LC2
Calibration Date: Today
13). Type of fuel
Type: 93
Percent of Ethanol:
14). Watched ECMlink how-to videos? Yes
I'm fighting a lean condition when I touch the throttle off idle. I have ISCPosition, AirflowPerRev, and the AFRs dialed in pretty good but can't seem to shake this lean stumble. The car cruises great, makes power, will hold a solid idle, but give it a little gas off idle and it goes lean and usually dies if I don't keep my foot on the gas.
In the log, you can see I give it throttle and the car stalls. I then I increase deadtime to 330 and start it up, it idles rich but it won't stall and it revs smooth off idle. I don't really want to run idle that rich, any ideas how to fix this?
Any ideas?
None
Yes
Yes
4). Ignition system
COP BR7es
Cylinder 1: 180
Cylinder 2: 185
Cylinder 3: 180
Cylinder 4: 180
Yes
No
No
Car running:
Sensor Brand: LC2
13). Type of fuel
Type: 93
Percent of Ethanol:
Any ideas?
