Please Support ExtremePSI
1G lean idel (log attached)
a91eagletalon
Supporting Member
278
13
Aug 24, 2005
Norfolk, Nebraska
ok long story short I pulled the motor repainted engine bay and put it back easy enough. with most every thing back in place the car starts kind of hard and will not stay running unless I give it some gas for a few seconds then it will idle fine. my concern is that the afr gauge goes from 13 or so to 15 to -- on the gauge at idle and it was cold i did not run it long enough to get it warm. but if you give it some gas the gauge will go all over then place and then settle back to -- on the gauge. it did not do any of this before I pulled the motor. I am a long time dsmer but I am very new to DSMLINK so I saved a log for you to look it the car was cold and only ran it for a couple seconds. let me know if you want a different log or what I can change on a side note is there any way to louse or accidently rest the tune in the car because it looks like nothing has been adjusted in the tune to me but I would not know.
Thanks
MJP
  • 2min log.elg
