1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
1G Lean Cyl 1/Rich Cyl 4
Posted by ViPER1313, Apr 15, 2018
Please Support ExtremePSI
  1. ViPER1313
    ViPER1313 Probationary Member
    6
    Joined Nov 21, 2006
    Ijamsville MD, Maryland
    Hello everyone; long time owner of a 1990 Eagle Talon AWD here. I pulled my plugs today to do a compression test and found that cylinder 1 appears to be running very lean while cylinder 4 is fouled / appears to be gray in color. My injectors were cleaned / balanced less than 1k miles ago, ECU has DSMlink v3 lite and was recapped several years ago. No vacuum / boost leaks that I can find. Compression does not appear to be the issue (numbers in photos below; not perfect but I don’t think it’s to blame.) I am thinking there is an issue with the coil pack, power transistor (ICM) or ECU because of the shared coil on 1/4. Car seems to run OK. Any other ideas what could cause this?
    Log in/Register to remove ads
    Featured Products from our Supporting Vendors
Share This Page
Loading...
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Miller Import Parts Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
