Jacolu3
- 638
- 130
- Jan 31, 2015
Lake Grove,
New_York
1). Any boost, vac, or exhaust leaks?
fixed one small boost leak on the brake booster line
2). Verified mechanical timing?
yes
3). Verified base timing?
yes
4). Ignition system
stock coils and ngk 7s:
5). Motor health (Compression Test)
good
6). Performed basic throttle body adjustments?
Idle Switch:
Throttle Cable:
TPS:between .63-.65
BISS:yes
7). Compression ratio
9.5:1
8). Any known bad sensors or brittle wiring?
no
9). Any DTC/CEL codes?
none
10). Electrical system
Car off (not running):good
Car running:good
11). Base fuel pressure and injector values
Base Fuel Pressure:
Injector Size (cc/min):FIC 1120
12). Properly calibrated and configured wideband sensor
Sensor Brand: Innovate
Calibration Date:less than 3000k miles ago
13). Type of fuel
93 octane
14). Watched ECMlink how-to videos?
yes
So this just started happening. A few weeks ago I went out logging my sd cruise and at the last log I was running good so made no adjustments.
2 weeks later(today) I take her out for a little ride and inbetween shifts it would go lean and bog for a few seconds. And even regular driving It seems to be a little on the leaner side. Also sometimes from a stop it will go lean on accelerating, and then be ok.
I clipped my log to show a spot where it was happening and ill also post the full log.
thanks in advance
-Brian
yes
yes
4). Ignition system
good
Idle Switch:
Throttle Cable:
TPS:between .63-.65
BISS:yes
9.5:1
no
none
Car running:good
Base Fuel Pressure:
13). Type of fuel
93 octane
yes
thanks in advance
-Brian
