brian9397gsx
- 1,551
- 87
- Apr 28, 2008
sioux city,
Iowa
Quality gaskets, I use mostly OEM on the bottom half of the motor anywhere fluids are. They dont cost much especially buying individual since there's only 3 main gaskets on the bottom. Then a lot of times I will use OEM crank and cam seals or fel pro. With the oil pan make sure where the bolt holes are are flat on the rail slot of times they are domed from over torque. I usually just buy new oil pans anymore since they can be had for 60 or so off rock auto. Just pay attention to not to over torque the fasteners as that can make gaskets squirm and distort the housing. Also on mine I cleaned all the bolt holes good and wire wheeled the bolts before install.
