95CarbonEclipse
- 1,279
- 5
- Sep 16, 2005
Yakima,
Washington
Note: This feature currently requires accessing the site using the built-in Safari browser.
What else do you want a picture of??
Mine appears to be the exact same one that EvoCarl has. I'll need to get something that measures in millimeters so that I can measure the intake ports to compare them with sd_ff22's measurements since his doesn't seem to have the EGR port or the extra nipple on the drivers side of the manifold.
Looks like your's has a hole drilled through the flange, like some we have seen. Does it have threads in this locations?
Pretty sure thats a Evo 3 manifold right there
My throttle body is about 65mm internal measurement which looks like it tallys upto your one.
So far I havnt seen a Evo 1 or 2 with the EGR hole on the manifold, also havnt seen a Evo 3 without the EGR.
That's what I'm leaning towards... it seems to make the most sense really.99% sure only the 3's have the EGR. MAYBE very very late Evo 2's
Yes... as mentioned a few posts back. The EGR port is bigger AND threaded on the face of the mani. I tried to take a picture of this last night, but for some reason the camera was being screwy.The EGR hole is bigger on the face and threaded right?
^^^ Any input from what's been discussed in this thread as far as the EGR port and the install?? Does your manifold have the EGR port? Are you still running the EGR or has it been blocked off?
Like I was saying, the throttle body that came with my IM actuates from the front rather than the back. 1G NT throttle body on the left (60mm) and wierd TB on the right(54mm) HMMM.
-Dan
No Evo came with a TD04
I think some Evo 2's also had the Evo3 big 16g..
The mini van/rvr things you guys mentioned are these things
