Please Support JNZ Tuning
Please Support STM Tuned
Kyle Henny's Drag GSX
Shit has gotten serious no more hx40 here
Thanks man. Yeah it's enough to blow my motor. I went with the 1.15 twin scroll t4 We'll see how she holds. Mahle and scat ftw!
Top mount is in the works, just finished collector mockup. Ready to weld.
It was making power, 68lb per min, on a 69lb per min rating my problems were untuned suspension, stock valve springs 8k short shifts, bogging into 2nd and bc272's, bald street tires and 1.9 60's all of these are going to be remedied.
Oh i did also find a nice pinch in my diaphragm 44mm mvr, replaced that, could have made a negative affect could have not i dont know, better safe than sry
As For your lag comment thats possible, but probably not considering the turbine is smaller and compressor exducer are the same spec better aero on both wheels, and ball bearing..twin scroll will make up for it so I'm actually anticipating the same 5200rpm 30psi if not sooner, but time will tell.
On top of it all i got a screaming deal so i couldnt not.
Also, I'm making a move to scottsdale arizona and will also be switching to e85 :)
130's traps on that turbo is not making power. That's a good 16g setup territory.
No one is going 140 with a bogged 2nd shift on that turbo and untuned suspension and street tires it's a driver mod thing too, i havnt been able to go to the track as much as I'd like. In fact, i only went once in july in 2014
There are obvioualy more factors than just the turbo car weighed 3100 with me in it too
Time will tell what this new turbo can do and the changes I'm making to compliment it. I'm confident everything will work out just fine
Damn Kyle, lookin good bro! Last time i was on the forums i remember checking ur build. I'm jumping back in to dsms to finish my abandoned project.
Great work on that mani
Had some issues with the stm half rad being a little thick so I'm getting an mk3 rad to fit under the rad support and then wastegate placement and welding!
Nevermind my other post. I see. Looks good man.
