Knock sensor leaking oil?
Posted by rivet0r, Sep 5, 2004
Please Support Ace Race Parts
  1. rivet0r
    rivet0r Proven Member
    479
    Joined Sep 22, 2002
    I just noticed oil running down the block from my knock sensor, is it shot?
    Kind of strange, any help would be great.
    Log in/Register to remove ads
    Loading...
  2. steve
    steve DSM Wiseman
    12,419
    358
    Joined Feb 3, 2002
    St. Charles, Illinois
    Well I'm not Buck or Luv2rallye :) but if the goo is leaking out of the knock sensor then it's time to replace it. A quick search will confirm that is the sign of impending knock sensor death
    Steve
    My DSM:
    Loading...
  3. rivet0r
    479
    Joined Sep 22, 2002
    Haha, thanks steve. Don't take my previous thread personally, I appreciate the help. Although I was waiting for them because had had spoken with them about it previously.
    Thanks,
    rivet0r
    Loading...
  4. steve
    steve DSM Wiseman
    12,419
    358
    Joined Feb 3, 2002
    I don't, they are both well respected, knowledgeable guys. Just pulling your chain.
    My knock sensor is just starting to do this too. It hasn't started dripping but I can tell I'll have to replace it sometime soon.
    Steve
    My DSM:
    Loading...
  5. rivet0r
    479
    Joined Sep 22, 2002
    Mine is leaking pretty bad actually. Enough to get on the axle and all the way down the control arm. Unless of course it's yet another leak that I don't see.
    Let's just say I blew some seals, which soaked my tbelt, and I just got finished replacing the whole side. Start it up, and of course, there is still another oil leak that I can't find, and I don't want to run the risk of soaking the tbelt again. So it's going to be sitting until I fix the leaks.
    I see oil dripping off of the knock sensor, so I know that needs to be replaced. I replaced the cam seals during the tbelt job, but somehow there is oil getting onto the outside of the cam sprockets.. doesn't make sense at all. The only possible thing I can think of is the valve cover gasket, that's got to be it.
    And last, there is a leak on the front right side of the block, I have no clue where it's coming from, and I'm worried that it could possibly be the headgasket. Anybody know if it's even possible to leak oil from the headgasket?
    Again, thanks for all the help.
    -rivet0r
    Loading...
  6. steve
    steve DSM Wiseman
    12,419
    358
    Joined Feb 3, 2002
    It's possible to leak oil between the head and the block since oil passages pass between the two but I'd expect you would have other things leaking too.
    If you have oil leaking down the knock sensor and not a thick goo it might be from your oil leaks and not the sensor breaking down.
    Steve
    My DSM:
    Loading...
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
