Please Support ExtremePSI
Please Support Rix Racing
ECMlink Knock Retard Disappeared
psychbiker1966
96
Aug 14, 2007
Houston, Texas
I have ECM Link v3 on my 2g and i have a weird situation. I log Knock Retard consistently when I drive but for some reason I can no longer find it in my displayed value column. Now I had my laptop in the car and a DSM mechanic was looking at my log and when I drove the car today I noticed it was no longer logging KR. I went to add it from my displayed values column and I can't find it. Did my Knock sensor up and die or something? Anybody ever had this happen?
Thanks.
Have you tried going to ECU-->Captured values? Add the knock retard, then you can display it in the Displayed value column. I had a similar issue logging my Wideband
I did under the EDIT tab field while I was at a stoplight.. I didn't see it there but I had to go to work and didn't have a lot of time. I hope it will be in there when I check again tonight. This time in the ECU tab.[DOUBLEPOST=1414844512][/DOUBLEPOST]I went in under captured values and its definitely gone. I guess I'm going to have to delete ECM link and re install it again.
Not even a delete and redownload could fix the problem. A rep from ECMlink called the tuner and they had to do some deep editing of the parameter coding. Some lines had been missing/edited. No idea how that happened.
