talontd92tsi
- 770
- 22
- Apr 2, 2005
Waynesburg,
Pennsylvania
Just wondering if you guys have any experience with these things. I was surfing the net the other day, thinking, man, I would like a bigger turbo with a billet wheel. Just because.
So I go to FP's website and drool over the green-black range. I am sure a black is too damn big for my goals with this particular car, So either a green or red. Green's were (are?) on sale for like 899 (+100 for an internal actuator).
So I did some searching about billet wheels and found Kinugawa's website and started looking around, and became intrigued, and started wondering, gee I have rebuilt a turbo before, and my current turbo is in great shape, so why not just swap wheels/covers and go for it.
Current turbo is an E316g. For cost effectiveness, I would like to stay on the TD05/7CM setup. that is already there. Just swap covers and wheels.
Soo...First I found this. (Link to the actual page does not work because the spam filter catches "SHI T" in it so heres a picture.)
Then I found this
Not sure which one would produce more overall power, and it looks like (at least the picture on the 11 blade wheel) that they have already component balanced this wheel, so bolt on and go... right?
Then I said, well, Let's see what you can find for compressor covers.
And I found these four options.
Stock style (sleeper20g style) cover. $99.00
http://shopping.kinugawaturbo.com/turbocompressorhousing4g63ttd05hdsm1gevoiii20g-1-1.aspx
2.4" inlet cover $109.00
http://shopping.kinugawaturbo.com/turbocompressorhousingtd05td0624inchesinletfit60-1wheel-1.aspx
3" inlet cover $109.00
http://shopping.kinugawaturbo.com/turbocompressorhousing3td06garrett60-1wheel-1-1.aspx
3" inlet SP cover $149.00
http://shopping.kinugawaturbo.com/turbocompressorhousing3td06garrett60-1wheel-1-2-3-1.aspx
And of course, I want to stay on an internal gate (because I don't really need an external gate, so why spend the green) They have options here too.
If I stick to the stock style cover they have these stock style actuators with spring pressures up to 22 psi (per their site) for $65.00
http://shopping.kinugawaturbo.com/turboactuatordsm1gevo1-3vr-4td05h14b16g17psi-1.aspx
Or if I wanted to get fancy, they have an adjustable actuator with changeable springs (up to 25psi) for 99.00
http://shopping.kinugawaturbo.com/turboactuator4g63ttd05hevo1-31gvr4galantvr4dsmeclipse.aspx
And if I choose to go to the 2.4 or 3" inlet cover, the only option I can find on their site is this guy for 99.00, again, changeable springs in the actuator.
http://shopping.kinugawaturbo.com/k...torfpgreddy3inchcover24inchcovertd05td06.aspx
So my options for a bolt on, td05, 7cm, billet 20g are as follows (both wheels are the same price, so I'm just looking at design benefits/drawbacks).
Stock style cover, Stock style actuator, $323.00
Stock style cover, adjustable actuator, $357.00
2.4 or 3" inlet, non SP & adjustable actuator, $367.00
3" inlet, SP, & adjustable actuator $407.00
The turbo on this car is in such pristine shape, I would not be afraid one bit to just throw it on there with out rebuilding it at all, I mean, it has ZERO shaft play, in any direction.
So in summation, the question is as such. Is it worth the cash to upgrade this over the current e3 wheel in there now? I think it would be a nice little bump in pump gas power (e85 is out of the question here, although I am considering building my own home-brew meth kit using the instructions on Tom's Turbo Garage's website ( http://www.turbomirage.com/water-alcohol-injection-parts-list.html ).
Does anyone have experience with these things at all? Good/bad/great/etc. Let me hear your opinions. If these things aren't total garbage, I think this would be a great way to build a badass bolt on turbo on a budget.
Then I found this
