redfield102j
- 170
- 7
- May 12, 2015
Spring Creek,
Pennsylvania
I recently bought this car it sat in a guys garage for over 10 years taken apart to have clutch put in. I bought it taken apart never hearing it run. Came with a spare motor with everything on it. I got the car home put clutch in and started the car took lil time to get going cause how long it sat. Got it started and it sounded great. Then a horrible rattle started and the engine moved like a broke motor mount. I shut it off and decided to put other motor in. I completley stripped new motor down to block and head. I took all old parts off other motor meaning intake,fuel rail,plugs,wires,knock sensor,turbo, everything. Got it all together and in the car. So started the problems. Went to start the car and had no spark. Couldnt figure out why. The spare motor came with a ecu also so figured screw it ill try it. Hooked it up hit the key and it fired right up. It ran threw the rpms without a problem seemed to be building boost and everything took it for a ride and it seemed like clutch was slipping. Brought it home and started the attempt to fix. Come to find out the clutch is working fine and it seems to be a power issue. Now ive done a boost leak test.. passed.. replaced all vaccum lines.. for nothing.. and the car isnt any better. It revs to 4k and goes all retarded them tries to die when ya let off gas. I dont understand it. First thing why did the old ecu not work on new motor and why cant i get the motor to run right with the ecu that works. I did have to swap the cam angle sensor from old motor to the new one.. so frustrating
