Mosebrosdsm
- 0
- May 18, 2015
Devils lake,
North_Dakota
Just got my crank back from the machine shop after a polish and ball removal. Mic’ed all the journals this is what I got. Stock 6 bolt crank
Need some help/suggestions if i should still use this crank. The specs are at the very lowest amount according to the service limits
1. Front correlates with oil cover side
2. Rear correlates with flywheel side
Mains: ordered from flywheel to oil cover
Horizontal 1.) 2.2433 2.) 2.2434
Vertical 1.) 2.2433 2.) 2.2434
Horizontal 1.) 2.2434 2.) 2.2434
Vertical 1.) 2.2434 2.) 2.2434
Horizontal 1.) 2.2433 2.) 2.2433
Vertical 1.) 2.2433 2.) 2.2433
Rods: from flywheel to oil cover
Horizontal 1.) 1.7706 2.) 1.7707
Vertical 1.) 1.7707 2.) 1.7706
Horizontal 1.) 1.7707 2.) 1.7707
Vertical 1.) 1.7706 2.) 1.7706
Horizontal 1.) 1.7707 2.) 1.7706
I hope you guys can understand this I tried my best to keep it thorough yet readable.
I read the service specs for the rod journals are supposed to be 1.7710-1.7717
Please help and correct me if I’m wrong. Where should I go from here.
