topstreet
DSM Wiseman
- 300
- 9
- Oct 10, 2005
Pewaukee,
Wisconsin
Hello Fellow DSMer's!
I have been planning and designing a new setup since before I pulled my old one apart. I am going to be putting this new setup together over the next year or so. Everything is being created with a few simple goals.
COST: This setup needs to be pulled off on a budget for several reasons. One being; when something on a setup needs to be changed, serviced or replaced... It sucks when it cost you a ton of money.
RELIABILITY: With my old setup, I never intended the car to be a track car. I have always said "it would be cheaper and easier to build a car that doesnt need to go down the road and be just as badass". Also, I plan to drive the car daily when the weather allows.
PERFORMANCE: Having tons of power to play with is fun, but being able to master the engine and the drivetrain in such a way that you can use it... That is killer! I have always loved the "road warrior" setup. Drive fun, Drive hard, Drive far...
As many of you know, you usually only get to pick 2 of these 3. I have started this thread to show that old fashion hard work, and new age technology can make one killer car.. And surpass that idea.
This is mearly a documentry of the rwd setup as it is going together. I am posting it in the most broad of the tech forums because I will be hand fabricating everything from front bumper supports, to rear parachute mounts and suspension... AND EVERYTHING IN-BETWEEN!! Its all for your viewing pleasure. More info on the car and what I do can be found on our web page. WWW.JHRACING.NET
Thanks!!!
Jake Hanhardt
Thanks!!!
Jake Hanhardt
