DJ23GSX
- 773
- 4
- Feb 22, 2004
W. Springfield,
Massachusetts
I just recently started to have issues with my AEM meth injection kit. I noticed I was getting some lean spikes in my datalogs so first thing I checked was the meth system. Upon running it with the test button on the controller (without the nozzle attached) I noticed that the pump nearly stops a few times during the test causing a noticable loss in fluid flow. Next thing I did was hook up a multimeter to the pump feed wires and watched voltage while pushing the test button again. With the multimeter hooked up you can see the voltage to the pump gradually rise like its supposed to only to fall for a split second and then continues to rise again like normal. Is this the correct way to be testing this and does this confirm that its the controller that's bad and not the pump?
