GstRacer
- 409
- 3
- May 6, 2003
BooneDocks,
Connecticut
ya i was wondering if it's good or bad to run no thermostat i know it will run cold witch is good but is there a thing as too clod i also have a blitz 1.3 radiator cap
Note: This feature currently requires accessing the site using the built-in Safari browser.
What is water pump cavitation? The good thing regarding regulating operating temps is that my digital fan controller will handle that. What I saw while driving was with fans always on. I'm going to set my fans to come on at 190 and off at 180.
Some bigger diesel engines suffer from cavitation due to high compression and undersized cylinder walls. Vibrations of the cylinder wall induce alternating low and high pressure in the coolant against the cylinder wall. The result is pitting of the cylinder wall that will eventually let cooling fluid leak into the cylinder and combustion gases to leak into the coolant.
It is possible to prevent this from happening with chemical additives in the cooling fluid that form a protecting layer on the cylinder wall. This layer will be exposed to the same cavitation, but rebuilds itself.
As a propeller or impeller blade moves through a fluid, it creates low pressure areas on it. Entrained air in the fluid will form into bubbles under the correct conditions, creating turbulence. This turbulence will feed more turbulence, more bubbling and eventually molecular boiling, where the actual material of the propeller will begin to erode.What is water pump cavitation?
That's low. I'd go for 200°F, or 205°F.The good thing regarding regulating operating temps is that my digital fan controller will handle that. What I saw while driving was with fans always on. I'm going to set my fans to come on at 190 and off at 180.
193°F isn't hot for a DSM. What are you measuring the temperature with?
um yea, you all are uneducated. If you run with no thermostat your car will actually overheat, because you give no time for the coolant to cool in the radiator. And yes its very bad to run without a thermostat.
