Intercooler Too BIG or Too SMALL???
Posted by 4g63telantra, Nov 12, 2005
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support VR Speed Factory
  1. 4g63telantra
    4g63telantra Proven Member
    Dec 10, 2004
    353
    Toronto, Ontario_Canada
    Just wanted to know, How can you tell if a Intercooler is too big or too small for a turbo?
    #1
  2. brute
    brute Proven Member
    DSM Profiles:
    Jun 29, 2005
    1,515
    41
    Madison, Wisconsin
    if the intercooler is too small to handle the boost, you will get heat soak. and if the intercooler is too big you will have boost spikes
    #2
  3. fwdturbobov1996
    fwdturbobov1996 Proven Member
    Feb 27, 2004
    559
    7
    Blue Springs, Missouri
    I thought you would also experience slow spool up if the intercooler is too big. Buddy got his fmic before his turbo and t25 spooled 1500 rpm later LOL. LOL .
    #3
  4. 420aonboost
    420aonboost Probationary Member
    Jul 28, 2005
    26
    coral springs, Florida
    yes thats correct...if your intercooler is too big then you will get more lag from your turbo
    #4
  5. 96bmwm3
    96bmwm3 Proven Member
    Mar 15, 2004
    42
    Sugar Land, Texas
    This is not necessarily true. Spool is a function of exhaust flow.
    #5
  6. tstkl
    tstkl Proven Member
    Feb 10, 2005
    1,999
    33
    east bay, California
    THIS IS NOT NECESSARILY TRUE
    if you dont know, dont speak....
    think about it, a larger intercooler has a larger volume, which means the turbo charger has to fill your larger intercooler with pressurized air before it starts filling the uicp, then the intake manifold, then the engine, if you increase the volume of your intake system after the turbocharger, the spool WILL decrease, doesnt matter how unnoticable it is to you, it will... thats why people ask, Will a 3 inch uicp give me too much lag? and why i went with short route piping over long route... saves a lot of piping, cutting down on volume...
    #6
  7. Slipstream
    Slipstream Proven Member
    Jun 8, 2004
    408
    7
    Northern, California
    In addition to the other replies please also note that turbos should have a rating for how many cfm of air they'll push...good intercoolers also have cfm ratings. Keeping this in mind when shopping for an ic will help you pick one that will at least flow enough air to keep up with your turbo, but not so much air that you're overbuying. (how well an ic actually cools the charge air is another matter entirely) but for volume sake this should get you started.
    #7
    SkyLineGtR-R34 likes this.
  8. 96bmwm3
    Mar 15, 2004
    42
    Sugar Land, Texas
    Ok, then I'll speak. Spool WILL NOT necessarily decrease.
    Check your definitions. Spool does NOT = lag. I will admit that 420aonboost did say "lag" and not spool. But the poster before said that an intercooler would decrease spool.
    Spool refers to a turbo's spinning up to speed and creating boost. This is a function of exhaust flow, geometry, etc. In fact you might even say the more volume in the system the faster the turbo will spool (probably shouldn't say this, I don't know for a fact, but looking at the decrease in back pressure I suppose you could argue that).
    Lag actually refers to how long it takes to spool the turbo when you're already at a sufficient engine speed to create boost. This can be affected by piping, intercooler, etc. But is usually not noticeable unless the componets you have added increase the pressure drop through your system considerably.
    Oh, and just because people wonder about the affects of certain parts and because you installed short route piping doesn't make that theory a fact.
    #8
  9. brn2race96
    brn2race96 Proven Member
    Nov 27, 2004
    32
    chicago, Illinois
    this is a usefull thread.... i have a 2g 6bolt with a 14b turbo. I was in the market for a intercooler, any suggestions as to what will be best for moi. I wanted to go fmic, will that be too big?
    #9
  10. JessesTalon
    JessesTalon Proven Member
    Dec 13, 2003
    619
    3
    Beaverton, Oregon
    If its heat soaking its too small.....
    just get a evo fmic... good cheap decent cooling and will handle at least 16g's no problems
    #10
  11. talonkid420
    talonkid420 Probationary Member
    Aug 21, 2005
    Castle hayne, North_Carolina
    What about a GT30? I know that I will need a bigger on then the on on my stock GSX
    #11
  12. ericbev
    ericbev Proven Member
    DSM Profiles:
    Oct 18, 2004
    624
    49
    Coal City, Illinois
    #12
    Dhan and DSMcamaro like this.
  13. tstkl
    tstkl Proven Member
    Feb 10, 2005
    1,999
    33
    ok lets go through this peice by peice... your right spool is not lag, but looking at spool is like looking at hp output and trying to nail down performance, a 400hp truck isnt faster than a 200 hp car,... what am i getting at? all that really matters is the final, noticable result, aka lag... why care how long it takes your turbo to create pressure if you cant use it?
    i dont even know what your talking about when you say the more volume in the system the faster the turbo will spool, are you talking about exaust or intake? either way i think its a false statement, since exhaust gas velocity is a lot more important the overall volume, (think if you had 500 liters of gas moving at 0 m/s, fast spool right?)
    i believe you arent familiar with modern physics, and the absolute gas equation:pv=nrt
    or for those of you that dont understand, (pressure) x (volume) = (number of molecules) x (some constant i forgot the name of) x (temperature)
    pressure drop is not caused by the components of your intake system, the reason why your intercooler has a lower pressure at its outlet than at its inlet is due to the fact that n, and r are constant, and v cannot change at the same rate as t is, so p changes as well as v, (colder air is denser, right? thats why you get a decrease in v with t, but p also drops some as well)
    and the reason why i said people wonder and i did install short route piping is because, like the concept that a bigger exaust pipe will flow more gases, some true facts make their way to the modern uneducated public, (and they feed off that info, which is why you have 5 inch mufflers on the back of civics, which doesnt help, but in there warped and twisted ways of looking at exhaust, it does)... and i installed short route piping because the lower volume will decrease lag, theres no way to get around physics... it will decrease lag, while my fmic will increase it since the volume of that is about 3 times as great as my old intercooler...
    im done, if i forgot anything, tell me...
    #13
  14. 96bmwm3
    Mar 15, 2004
    42
    Sugar Land, Texas
    I think you've made my point for me, thanks. You just lost all credibility with those comments. BTW, R is the universal gas constant (8.31 J/mol x K). I've used it a few times.
    As intake temperature decreases (through your intercooler), your volume doesn't change it's just more dense. Pressure lose IS due to the components in your intake system. Energy is lost through your intercooler and piping due to friction - this is why you see a dP across your intercooler.
    Hey everyone, if you don't add an intercooler to your cars you'll see the same pressure at your intake that you did at the outlet of your turbo!!!!
    #14
  15. DSM BEEYACH
    DSM BEEYACH Proven Member
    Jul 28, 2005
    106
    3
    ERIE, Pennsylvania
    You Sir are totally correct i'm glad to see someone that knows what there taking about. :thumb:
    #15
  16. CanadianTSi
    CanadianTSi DSM Wiseman
    DSM Profiles:
    Aug 12, 2002
    4,365
    53
    Kingston, ON_Canada
    Your friend had a boost leak.
    People make too big of a deal about Intercoolers being to big, its just not that big of a problem in reality, maybe a couple hundred rpms of extra lag but that's it.
    #16
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
