b00stedtalon2
- 1,084
- 619
- Dec 19, 2005
Detroit,
Michigan
Looking for a comparison of a EVO 3 intake manifold vs Magnus V4. Dyno, butt dyno or track results.
Note: This feature currently requires accessing the site using the built-in Safari browser.
Comparison on what?
How your car is set up, power level, and what the car is being built for will determine the pros/cons for each...Just like every other part on the car.
@GST with PSI . Did you previously have a V3? I have both but still haven't gotten around to installing the V4. I have a ported/deshrouded 1g cylinder head and I haven't started the headwork on the 2g head I have, so it wouldnt be good comparative data.
If you are marginal on coverter with the Evo, you will likely not get on it with a Magnus.
Dude, it's night and day down low. It was at least a 1000rpm change in boost threshhold. Didn't change much at the track. But cruising around town it helped a lot.
