Quaxel
- 0
- Mar 16, 2012
Minneapolis,
Minnesota
Ok, so my 95 gs (daily driver/project car) has an ignition problem. the key wont stay in the on position, i have to prop it there with a little metal thing and brace it against my dash. huge pain. I purchased and installed a new ignition cylinder the problem persists, and i don't wanna dig into the ignition anymore. so i was thinking i could just wire a toggle switch, or a pair of toggle switches to control the the ACC position and ON position. from there i can use the key to turn to ignition and start the car. (it starts right up and works as long as i keep the key from sliding too the acc)
so does anyone have a diagram, or description or experiance putting in toggle switches or buttons or something to control the cars on/acc position? i just wanna be able to keep my car running, if installing a push-to-start is a must i'm willing, but using the key in the ignition is just fine. thanks, i know how to wire in switches and mount them and such, just don't know what wires il need, or how to make sure the battery is not being drained 24/7
any help is appreciated!
oh and i treid searching around a bit, couldn't find what i needed, if you'v seen a thread with the answers, link it
thanks!
thanks!
