Ignition Switch (electrical) Fix
Posted by DSMDirkah, Nov 29, 2011
Electrical Tech - Wiring, turbo timers, electronic boost controllers, gauges, fuses, wiring harnesses, wire tucks, car audio, and all other electrical component discussions.
Please Support STM Tuned
  1. DSMDirkah
    DSMDirkah Proven Member
    Oct 22, 2005
    150
    3
    Stoneville, North_Carolina
    So I had an intermittent no crank issue. Of course this turned into a no crank issue. The car is a 95 Auto AWD Talon. I checked everything starting from the starter and worked my way back to the ignition switch. The relay tested fine so I worked to the switch. I found that the ignition switch was not operating correctly so I changed it out with one that I had on a parts car. Well that one did not work either! So I took apart the switch and everything looked fine inside both of them. They are simple devices. Next thing I did was insert a flat head screwdriver in it while it was hooked up to manually test it. It worked! I put it back in the ignition switch and it was a no go. So here is how I fixed it:
    Here is a pic of the switch where I manually tested it with a screwdriver (circled in green is where the screwdriver goes of course):
    [​IMG]
    This is what I had to do to get the switch lined up properly so that it would activate:
    [​IMG]
    The red parts were "slotted" carefully using a drill and taking my time. When I installed it, I clocked it so that it would have extra travel to engage the "ST" signal. After this was done the car starts flawlessly.
    Many might say just go and by a new one. I am cheap and feel that there is no reason to throw away a good working mechanism.
    What caused this issue? I have some thoughts on this. There was slight compliance in the plastic housing that might have been caused by years of use. The square armature inside the lock cylinder might be worn out of spec (maybe this caused a loss of designed travel).
    For whatever reason this issue happened, maybe this write up can help save a poor DSMer who just needs their car to start. Thanks :thumb:
    #1
  2. DSMDirkah
    Oct 22, 2005
    150
    3
    Wanted to bump this thread one more time to say that this fix still works to this day. So I guess it can be a "trusted" fix LOL.
    #2
  3. turboglenn
    turboglenn Proven Member
    Nov 5, 2007
    5,389
    82
    RIpley, West_Virginia
    I'm with ya, if i can fix a problem with a dremel or drill that would normally cost money (especially now being disabled) i'm gonna do the fix first.
    I have recently gotten to where it takes a few tried to get the cranking going or turn it just right to get it, and my other options were either push button or use button #2 on my keyless entry to activate the relay but it's a slow to respond "on" signal that would aggrivate me... I might just go this route but the allure to do something unusuall and different from most is quite tempting, so if i do in fact go "push button start" i want to do something totally un-expected and different from the typical new erra push button start systems on todays cars....
    I wish i knew more about RFID and interfacing it, I"d have the car where it unlocked and locked with my proximity and then started with a combo of say clutch down + cruise cancel by having the ignition put to "run" with the RFIC prox, then the combo of cruise and clutch would be easy
    guess it will just take some googling LOL
    #3
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
