CDgr97GSX
- 136
- 4
- Feb 11, 2009
Romania,
Europe
Hi guys. I need some help with my tune since the guy who tuned my car(MY1GDSM-Stacy) is no longer in the business. I had some problems with my idle when i stat using the car again after few months of garage parking. Everything was ok in normal driving or WOT but the not the idle, the engine stall every time when it was running at idle after going few times rich then lean. Strange think was that when i had the engine warm and going few times WOT then the idle start to be ok. I've checked the settings with EcmLink and when the idle was ok the car was running in open loop and started to go rich-lean as soon as the ECM was going in closed loop. I thought is the IAC sensor so i've change it even if the old had the coils in order. I've adjusted the throttle cable and biss screw but the idle was still the same. I did some adjustments at SD table and global and dead time and now the idle is better all the way but the car is running in open loop at idle. I would like to solve this problem and i need some help. I'm still learning to play with EcmLink since i don't have someone to do the tune for me anymore. Thanks
