godschylde777
- 668
- 319
- Jun 3, 2009
houston,
Texas
GM, I am using a Q45 TB. I was not sure if I needed this or not or if I could do without it. And help would be appreciated.
Note: This feature currently requires accessing the site using the built-in Safari browser.
Actually they both work. I have both plastic and aluminum purge valves. The only difference is the plastic is the updated version just like in the DSM. Both will bolt up just fine to a dsm isc. You need to match the two up. DSM plastic to Nissan plastic...and vice versa. Or you just just use the Nissan purge valve as is and splice in the Nissan plugJust to update this with what I have found in the yards, the part is from a 95-98 Nissan Maxima and its the purge valve, however alot of them are made of plastic, the plastic ones will not work!, the stepper motor is held on by two screws on top instead of the dsm like three screws and it looks like the stepper part is made completely different than the older aluminum body ones.
So where would it bolt to?Actually they both work. I have both plastic and aluminum purge valves. The only difference is the plastic is the updated version just like in the DSM. Both will bolt up just fine to a dsm isc. You need to match the two up. DSM plastic to Nissan plastic...and vice versa. Or you just just use the Nissan purge valve as is and splice in the Nissan plug
Remote mount it with one of the methods stated above...So where would it bolt to?
Yeah . I just found a post. Ordered the parts. ThanksRemote mount it with one of the methods stated above...
