I pray this is "Only" Lifter tick [Video]
Posted by strayfe, Mar 11, 2009
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support VR Speed Factory
  1. strayfe
    strayfe Probationary Member
    DSM Profiles:
    Dec 25, 2008
    16
    Tacoma, Washington
    My cars been starting to have problems, It sounds alot like lifter tick so I am hoping it "is". Oh crap I hope I wont half to slice my pockets into half on this one.
    YouTube - 1g lifter tick?
    Please click HQ button so you can hear the sounds properly.
    Here is my biggest question. Is my car "Safe" as a daily commuter? Any feedback/knowlege on the problems I am having it greatly appreciated, I really hope this is only lifter tick. Better yet It would be wonderfull If it is something that only requires me to tighten/loosen some pulleys.
    #1
  2. Lofty
    Lofty Moderator
    DSM Profiles:
    Jul 27, 2008
    1,436
    26
    Waukesha, Wisconsin
    Sounds like the T-Belt is rubbing.
    Just my personal opinion.
    Lifter tick *SHOULD* go away when you give it gas.
    Rod knock will not.
    #2
  3. JusMX141
    JusMX141 Moderator
    DSM Profiles:
    4
    Dec 13, 2005
    12,541
    475
    Greensburg, Pennsylvania
    Sounds to me like the beginning stages of rod knock.
    Rod knock normally starts by being more pronounced at a certain RPM (around 2k-3k) and will often be loudest upon engine deceleration, when the combustion cycle is actually working to slow down the spinning crankshaft and loading the rod bearing in the opposite manner in which it would under acceleration.
    If I were you I'd drop the oil pan and change all the bearings now before it destroys the crank if it hasn't done so already. This job shouldn't take much more than an hour and requires only a few tools. If nothing else it will give you piece of mind knowing your engine has new rod and main bearings.
    What does your oil pressure look like at idle? Any metal in the oil?
    #3
  4. joro702
    joro702 Proven Member
    Aug 15, 2008
    38
    Hillsborough, New_Jersey
    sounds like rod knock to me lifter goes away after a few min and has a different sound.
    #4
  5. strayfe
    DSM Profiles:
    Dec 25, 2008
    16
    Tacoma, Washington
    If I leave it at idle for about 10 mins, the oil pressure is about bare minumum. Under hard acceleration and driving freeway/doing quick little pulls brings the oil pressure anywhere between a quarter way to 45%.
    Also under hard acceleration in 2nd gear the PSI barely reaches 8 when almost to 7k rpm, then the PSI sputtles from 8psi to 6psi really fast, with a very distinct whistle/vaccuum, so I think I might also have boost leak OMG
    Could you possibly point me in the right direction to some good info on how to swap the rods, as I will probly be the most wet I will get my hands on this car since I baught it last year.
    #5
  6. JusMX141
    JusMX141 Moderator
    DSM Profiles:
    4
    Dec 13, 2005
    12,541
    475
    Something in the general area of the timing belt doesn't sound right either, as mentioned above. I'd start pulling accessory belts and see if the grinding sound goes away, eliminating the water pump and alternator as possibilities. You may even want to remove your harmonic balancer and try running the car with it removed. I've seen cases where a junked harmonic balancer will sound EXACTLY like a rod bearing failure.
    #6
  7. Boost92awd
    Boost92awd Proven Member
    Jan 23, 2008
    1,063
    3
    Waukesha, Wisconsin
    Oil pressure seems a bit low, which would make me think something is wrong internally in the motor.
    #7
  8. 4pistons
    4pistons Proven Member
    DSM Profiles:
    Nov 13, 2002
    590
    16
    Bolingbrook, Illinois
    Comments = my experience .... may not = yours
    Doesn't sound like rod knock, it's too intermittent, but something's wrong.
    Check your water pump pulley for wobble. Pull your upper cam gear cover and check cam gears for wobble. Check that your harmonic balancer hasn't separated. (Common on 1Gs)
    Please, please, please, don't rev an engine that sounds like that! Or any engine you think may have a catastophic problem. You'll only make it worse, or push it to failure. Find the problem first.
    Rick - '91 GSX :dsm:
    #8
  9. zhjiln
    zhjiln Proven Member
    Jul 12, 2008
    364
    Fresno, California
    definitely not your lifters....
    turn off car now.... dont do more damage by driving it...
    #9
  10. MidShipCivic
    MidShipCivic Proven Member
    Apr 22, 2005
    542
    4
    Orlando, Florida
    You're really lucky I've never experience rod knock like that where the engine runs still.
    That is rod knock for sure, your oil pressure is too low.
    #10
  11. nuclearr
    nuclearr Proven Member
    DSM Profiles:
    Jun 22, 2004
    1,201
    11
    Slidell, Louisiana
    Sounds like a balance shaft bearing to me. You also have a belt or pully issue. With the rubing noise when you did the p/s pump shot.
    #11
  12. talondave
    talondave Supporting Member
    DSM Profiles:
    Oct 27, 2008
    1,135
    23
    Oakland, Maryland
    I have had my share of blowing rod bearings, and that is a spun rod bearing.
    #12
  13. hondamunchergsx
    hondamunchergsx Proven Member
    DSM Profiles:
    Oct 15, 2003
    70
    reisterstown, Maryland
    mine made the same exact sound right before a bolt on the U bend of the rod snapped and knocked a whole through my block
    drain oil , drop pan and check for chunks of metal
    #13
  14. nyTalonTsi
    nyTalonTsi Proven Member
    Sep 5, 2008
    443
    Buffalo, New_York
    Drop that oil pan. That oil pressure is def. too low. Unless the gauge is shot.
    #14
  15. PIMking
    PIMking Proven Member
    Jan 29, 2008
    1,433
    tuscaloosa, Alabama
    Thats what I was going to ask him to do.
    Are you going through belts?
    #15
  16. Rob10_99
    Rob10_99 Proven Member
    DSM Profiles:
    May 22, 2005
    1,658
    Ptown, Arizona
    Yeah totally rod knock, like said before, don't bother starting it again in case it throws a rod.
    How about those stroker kits?
    edit~
    That's why it's called lifter "tick" and rod "knock"... huge difference.
    #16
  17. strayfe
    DSM Profiles:
    Dec 25, 2008
    16
    Tacoma, Washington
    So should I buy a new oil pan and replace it?
    #17
  18. strayfe
    DSM Profiles:
    Dec 25, 2008
    16
    Tacoma, Washington
    I am really starting to wonder if this problem is all related to when I bought the car. The origional owner had mentioned to me when I made the purchase that the car had a small oil leak. The leak has seemed to get worse over the months. I litteraly wenth through an entire liter in 3 weeks. In which I only drive 9-15 miles a day.
    #18
  19. PIMking
    Jan 29, 2008
    1,433
    tuscaloosa, Alabama
    Your old oil pan is fine as long as its hasnt looked like it went through a war.
    Just get a new pan gasket.
    #19
  20. JusMX141
    JusMX141 Moderator
    DSM Profiles:
    4
    Dec 13, 2005
    12,541
    475
    If that's the story, then I'm going all-in on rod bearings. Somebody, SOMEWHERE has driven this car low on oil as a result of that leak.
    My GS leaks oil profusely from the rear of cylinder head- it has for 5 years now....but I know that I need to add a quart every 2 weeks or so depending on how much it's driven. It's been like this a while....I'm just waiting for something major to happen so I can use it as an excuse to build the engine. It runs too good as a daily driver to tear it down. If someone who's not good on maintenance took my car, it would be dead in a month.
    Good places to look for oil leaks on 4G63's with higher mileage are the cam seals and the rear main seal.
    #20
  21. 99GST83
    99GST83 Proven Member
    Dec 17, 2008
    62
    Emmitsburg, Maryland
    That is a rod bearing.... 100%.... I had the exact same sound in mine 2 weeks ago, tore it apart, and found out that my 7 bolt did what I hoped it wouldn't do. It took a walk. Crank walk is very common on the 7 bolt cranks. I had to replace all bearings and my crank due to a crack in the oil port. Also, I had a seized balance shaft, 2 colapsed lifters and a blown turbo. YAY!!! Good luck on your rebuild...
    #21
  22. Redwidow
    Redwidow Proven Member
    DSM Profiles:
    Aug 11, 2008
    366
    7
    Coldwater, Michigan
    Take a mechanics Stethoscope and start putting it around the engine on things it may be like the oil pan, or valve cover and pulleys. This should pin point it and get you a good idea of what it is.
    #22
  23. thewombis
    thewombis Proven Member
    May 25, 2008
    69
    Hilton, New_York
    Ouch.. +1 on rod bearing.. :hmm: good luck.
    #23
  24. Judaspriest22
    Judaspriest22 Proven Member
    Feb 17, 2009
    51
    Brentwood, Tennessee
    i like how many problems the 2.0L are having, and how little my 1.8 4g37 with 200k+ miles on it has, especially considering i beat the heck out of that little motor, no leaks, no smoke, no nothin.(except my fan hasnt been turning on lately)
    #24
  25. nyTalonTsi
    Sep 5, 2008
    443
    Buffalo, New_York
    Nice. Dont push your luck.
    I agree that does sound like a rod bearing.
    #25
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
