Hyundai 4G63 head
Posted by steve-o_95_GST, May 8, 2009
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support Feal Suspension
  1. steve-o_95_GST
    steve-o_95_GST Proven Member
    DSM Profiles:
    Feb 29, 2004
    369
    12
    Ft Lauderdale, Florida
    Does anyone know anything about the hyundai 4G63 head?
    I told a friend of mine that I was looking for a 2g head and he told me that he had a head from a '96 Hyundai that looks pretty similar to the 2g 46g3 head by comparing the intake ports. Im wondering if the head made by Hyundai is a copy of the mitsu head or slightly different. If they are different, can anyone tell me the differences between the two?
    -Steve
    #1
  2. Dsmj89
    Dsmj89 Proven Member
    Nov 11, 2008
    2,150
    9
    Miami, Florida
    What year hyundai did it come off of ?
    Regardless those motors were made only for about a time frame of 2-3 years on those cars, almost right along till they stopped production of the 1g, the intake manifold ports on the head resemble those of a 1g not 2g. I went a few months back to a junkyard and inspected one pretty well and saw they were the same all around.
    It should drop right in on a 1g with no problem.
    They pretty much used a mitsu block and they only slapped on the hyundai name on top of it, that's it.
    #2
  3. rush2252
    rush2252 Proven Member
    DSM Profiles:
    Apr 14, 2009
    1,301
    5
    Blanchard, Oklahoma
    +1 Its still a 4g63 im pretty sure the only difference is the HYUNDAI name on the valve covers.
    Kolby
    #3
  4. DSMified92
    DSMified92 Proven Member
    Sep 22, 2008
    143
    shelbyville, Tennessee
    all a hundai is is a 4g63 with a different valve cover because my budy has 1 in his shop that he is building mildly and there is no diifernce now by the head i dont know if it is similar to a 2g or a 1g:hmm:
    #4
  5. steve-o_95_GST
    DSM Profiles:
    Feb 29, 2004
    369
    12
    I believe he said it was of a 96. I thought they were in the car longer than that. I did a quick google search and I found they were in the sonata from 92-98 I dont know if they bought the tooling from mitsu from the start or just got parts from them as they were made but if it were the later, then maybe there could be a possibility of Hyundai using the 2g head as well. I dont know if this would be true or not but would be nice if it possibly could be the 2g head. I havent looked at it yet to tell or not for myself, and wont get the chance to until next week sometime.
    #5
  6. rush2252
    DSM Profiles:
    Apr 14, 2009
    1,301
    5
    Blanchard, Oklahoma
    Werent the sonatas NT though?
    #6
  7. steve-o_95_GST
    DSM Profiles:
    Feb 29, 2004
    369
    12
    They were. I didnt really think of that until you mentioned it, but they did have non turbo 4G63 in the 2g eclipse sold in europe. Its a long shot but Im just kind of hoping its what Im looking for because its free :coy:
    #7
  8. DSM "BISH"
    DSM "BISH" Proven Member
    Sep 10, 2008
    240
    Erlanger, Kentucky
    this wouldnt be suprising becasue the new hyundai genesis uses the same 4B11T motor out of the new evos. one of the reasons it is a pretty sweet car. but what year and model hyundais are you guys talking about having the mitsu 4g63 in them? i am very interested in this article.
    #8
  9. awdcsm
    awdcsm Proven Member
    Dec 15, 2008
    85
    Edmondton, AB_Canada
    the heads are indentical except the camshafts
    i planning on using swaping my 4g63 head for a 4g67 n/t head. the 4g67 head has big intake ports like a 1g head but i has a smller combustion chamber; 4g63 : 47cc and the 4g67 : 43cc. with this 4g67 head and evo 8/9 piston my compression should be around 9.1 or 9.0 c/r.
    for more info go to
    Project Zero G Forums ~ View topic - 4G61 head info
    #9
  10. steve-o_95_GST
    DSM Profiles:
    Feb 29, 2004
    369
    12
    Since he thinks it looks like a 2g head it maybe be one of these. I will check it over and see what really is sometime this coming week. Just to be sure Ill probably cc the head to verify. Thanks for the link :thumb:
    #10
  11. toyotaturbo
    toyotaturbo Proven Member
    DSM Profiles:
    Apr 10, 2006
    178
    Aberdeen, Maryland
    We went 9.90 with a head off a G4CS 1997 Sonata.......It has the small ports like a 2G. We had to hog it out a little for the 1G head studs to clear......but not much else is different.
    #11
  12. MidShipCivic
    MidShipCivic Proven Member
    Apr 22, 2005
    542
    4
    Orlando, Florida
    I have a 1997 Sonata engine and the code is G4CP it has 1g style intake ports, 6 bolt crank PCD, and the off key thing about it is that it has 1g characteristics but 2g angle sensor specifically 95-96 2g sensors.
    [​IMG]
    [​IMG]
    [​IMG]
    #12
  13. donniekak
    donniekak DSM Wiseman
    DSM Profiles:
    Mar 23, 2008
    4,113
    513
    Surprise, Arizona
    You have discovered the secret of the karking 6-bolt swap. 6-bolt bottom end, 2g crank sensor.
    #13
  14. gorf
    gorf Proven Member
    DSM Profiles:
    Dec 13, 2004
    498
    4
    Chapel hill, North_Carolina
    That's what I was thinking.
    Nothing more than using a front cover from a hyundia??
    #14
  15. MidShipCivic
    Apr 22, 2005
    542
    4
    Orlando, Florida
    No, the oil pan is curved around the cover and the side tin cover takes a different shape.
    #15
  16. donniekak
    DSM Profiles:
    Mar 23, 2008
    4,113
    513
    Surprise, Arizona
    Hyundia block, front cover, and oil pan modified for a drain. You replace the pistons with turbo pistons. Bam, 6 bolt turbo, with 2g sensors. The mounting bolts for the front cover and oil filter housing are different than a dsm, so they must all be used together. I thought that a 6-bolt hyundai was a common swap into a 2g.
    #16
  17. MidShipCivic
    Apr 22, 2005
    542
    4
    Orlando, Florida
    It's not because this engine was only in the Sonata for 2 years with this setup 96-97, I saw it in the junkyard untouched and I noticed that it had a plug going behind the timing belt cover. I don't see that much in fact, when I first got it back home and searched I don't see much info on it at all.
    #17
  18. AWD_Hybrid
    AWD_Hybrid Proven Member
    Apr 1, 2009
    174
    Sydney, Australia
    steve-o_95_GST a coupla things about the Sonata head for your friend.
    1 - To fit a 2G inlet gasket, I trimed the top of the gasket port 1/16"
    2 - I verticaly ellongated the bolt holes 1/8" higher so it can drop 1/8"
    This makes an Evo 1-2-3 inlet gasket line up with the ports.
    The floor of the Sonata inlet port is 1/8" lower than our Mitsu 2Gs.
    ** DON'T use the Sonata cam bearings caps with your Mitsu Cams **
    ** They are slightly smaller in Diameter and will strangle Mitsu Cams **
    ** I found out the Hard way. BOTH my Evo cams dowl pins sheared off **
    ** You can guess where my valves ended up after that :ohdamn:
    Other than that, Yeah a Sonata small inlet port head is a cheap 2G head.
    Cheers !
    #18
  19. dsm'sROCK
    dsm'sROCK Probationary Member
    May 18, 2008
    7
    derry, New_Hampshire
    sooo...hyundai bought 4g63's for ther cars???
    #19
  20. donniekak
    DSM Profiles:
    Mar 23, 2008
    4,113
    513
    Surprise, Arizona
    They used 6g's to.
    #20
  21. dsm'sROCK
    May 18, 2008
    7
    damn thats sh**ty...
    knowing crappy korean brand is using your engine
    #21
  22. MidShipCivic
    Apr 22, 2005
    542
    4
    Orlando, Florida
    Wrong way to think, Hyundai has changed big time awhile ago..
    #22
  23. NitrousBob
    NitrousBob Proven Member
    DSM Profiles:
    May 24, 2004
    124
    Montesano, Washington
    #23
  24. 95'RS-T
    95'RS-T Proven Member
    DSM Profiles:
    Mar 10, 2009
    438
    Germansville, Pennsylvania
    I know this thread is old but, I found a 98 Hyundai head like the one in the video above, and was wondering if there was a way to modify my 2g t-stat housing to fit this head, or maybe modify the head? Because the head looks brand new, and it would be a shame to pass up if I didn't have to.
    #24
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
