98awdturbo
- 61
- 1
- Dec 9, 2010
Waterford,
Michigan
I am 20 minutes of work away from starting my Talon for only the 2ND time in the 2 years I have owned it. I'm running a HX40 with DSM BEP housing on a FP manifold. My issue is my -10 oil drain. No matter what combination of fittings (straight, 45*) and/or hose length I cannot get it to fit. either there is too much angle on the braided line causing it to almost kink or the fitting to the turbo is hitting the roll stop bracket. The center housing is already somewhere between 6 and 7 oclock so i dont want to rotate that out anymore (it would have to be between 7 and 8 for the fitting to mate). Anyone ever run into this? Any suggestions would be great!
Thanks
-Chris
Thanks
-Chris
