eclipsyco
- 582
- 16
- Nov 19, 2011
Somewhere in,
Central_America
So as the titles says! I've searched and found some other guy in this forum with he had a similar problems BUT with an ebay copy of a Megan Racing t3 manifold in my case I'm using the dsm BEP housing with FP race manifold the compressor housing clears just fine the water pipe but hits the block right behind where the hole of the transmission bolt is I'm sure I can grind the compressor and just make it a tight fit but all the people I've read their builts with the same manifold and turbo don't have any problem at all except for bending the water-pipe a little any ideas what it might be? Or maybe is normal, I don't know!
7bolt block, genuine HX35, FP race manifold all studs are straight on the head, gasket and manifold lines up ok!
